It is currently Wed Nov 11, 2026 6:05 am
 Post subject: vss
PostPosted: Tue Aug 09, 2005 8:55 am
hi i was told that the vss is in back of dash....if so is it hooked to speedo cable...thanks.....1987 cutty ciera 3.8,,,i was told it may be on front drive train ???
PostPosted: Tue Aug 09, 2005 12:10 pm
Yes...the VSS...the sensor itself, is located on the transmission, you should be able to see it in the engine compartment.
No, it is not hooked up to the speedo cable (if you have one), it is for the computer...and if your speedometer is electronic it also uses it.
 Post subject: vss
PostPosted: Thu Aug 11, 2005 9:22 pm
thanks back.....but were in eng-carpartment,,,,,have code 26 vss maybe the wire needs cleaning or loose thanks..........
