It is currently Sat Nov 14, 2026 8:21 am
 Page 1 of 1 [ 6 posts ]
 Post subject: 89 ciera speedo bouncing
PostPosted: Thu Nov 03, 2005 8:47 pm
I have just acquired this car and did a tune up on the vehicle and the speedo bounces driving down the road and even worse on the back country roads. I am not throwing any error codes.
anyone have any ideas?
thanks in advance
Jeff
PostPosted: Fri Nov 04, 2005 12:49 am
I believe this topic has been covered, the speedo cable needs to be lubed with special, speedo cable lube.
PostPosted: Fri Nov 04, 2005 10:05 am
I wonder though, wouldnt an 89 have a digital-analogue speedo (oxymoron, i know). My car has a digital speedo, but its an analogue needle. Maybe an intermittant speed sensor cable? County roads would make the situaton worse?
PostPosted: Fri Nov 04, 2005 12:38 pm
IF it has a VSS, then replace it. There is no fixing it if the it has an electronic speedo then this is the only thing aside from a a bad wire that can cause this.
PostPosted: Sat Nov 05, 2005 11:49 pm
what are the odds on the actual cluster going bad?
I dont have a speedo cable i have the vss/electric pick up
PostPosted: Mon Nov 07, 2005 10:37 am
If it were the Speed Sensor, I would think the vehicles computer would bring that up as an error code seeing missed pulses. So, the guage would be a good place to start looking for an intermittent connection. Sounds like something is just loose or not making a constant connection.
On my car, the guage just "plugs" into the dash. Check the connector for firm fit, and no damaged pins.
Users browsing this forum: Bing [Bot] and 13 guests
