It is currently Thu Nov 12, 2026 7:26 pm
 Page 1 of 1 [ 14 posts ]
 Post subject: Need Help Idle High
PostPosted: Wed Nov 23, 2005 10:21 am
Just bought an 87 ciera from my grandma, when I start it, it idles high but does not idle low when warm. But when i turn it off and start it agin its fine, idles rite. Im thinkin the computer or a sensor. please help.
PostPosted: Wed Nov 23, 2005 11:39 am
Hard to say with this little information... Got any other details that might help? Does your Check Engine light come on at all?
PostPosted: Thu Nov 24, 2005 3:16 pm
yes, as a matter of fact it does come on. What does this mean?
 Post subject: high idle
PostPosted: Thu Mar 30, 2006 9:44 am
hi did you find out what the problem was?????i have the same problem
PostPosted: Thu Mar 30, 2006 9:53 am
I had this problem and it turned out to be the choke, but Mines carburated and probably isnt any help to this, but i delt w/ mine for months and spent alot of money so, just a thought that might save you some time.
Josh Egeberg
CCC
 Post subject: idles high
PostPosted: Fri Mar 31, 2006 9:46 am
this is weird i start car idles high ..i put it in drive then idles down no sevice light.......leave it in park idles high then light comes on,,,still high ilde drive off and light goes out.......code 24
PostPosted: Fri Mar 31, 2006 2:01 pm
From what I found, this is the description of code 24:
Vehicle Speed Sensor Sensor/Circuit.When engine speed was between 1200 and 4400 RPM and throttle position angle was less than 2%, the MAP signal showed low voltage (high manifold vacuum) for at least 5 seconds.
Hope that helps.
PostPosted: Fri Mar 31, 2006 10:29 pm
do i need to change the map sensor,,,,,all ready changed speed sensor???? thank you
PostPosted: Sat Apr 01, 2006 9:50 pm
then there could be something wrong with the speed sensor, or the circuit connecting it. There would be a different code for a MAP sensor error. The description is quite technical, I appologise.
PostPosted: Sun Apr 02, 2006 2:25 pm
Hope that helps.
Not to try and hi-jack the thread, but it may bring up some more info...
88, would this cause the car to go into open circuit mode (code 24) (or whatever it is to make the car use tons of un-needed gas) cause I have a feeling thats my exact problem, but I'm scraping pennies so I cant exactly replace it right now... :(
PostPosted: Mon Apr 03, 2006 8:47 am
hi i think i found the problem...the park nerural switch out of ajustment... runs fine now .......thank you for all your help
 Post subject: park neutral switch
PostPosted: Wed Apr 05, 2006 8:45 am
is it hard to replace this switch,,,,,,,it needs replaceing its doing it again thanks
PostPosted: Wed Apr 05, 2006 10:36 am
You haven't hijacked it more than it has been hijacked already.
Please start a new thread for your own questions. While you may have the same situation, taking "control" of someone else's thread is somewhat rude.
[hijack="andrewk"] Hope you get it fixed... it doesnt sound fun...[/hijack]
PostPosted: Thu Apr 06, 2006 8:44 am
87delta, a lot of codes will throw the computer into open loop mode, therefore burning a LOT of gas. The best idea, is to check your computer for error codes. There might be more than one error code. Let me know (start a new thread if you will)
