i replaced my power steering pump last month but the car is still jerking when cold and after it stalls a few times or i put it in park and rev it. It works fine so i have a feeling it really needs to be bled out good.
Jerking?stalling? Please elaborate.
Are you saying after it warms up the steering returns to normal performance?
You diddnt change the fluids when you changed the pump?
I would say, either water or air is in your ps fluid.
I had a similar problem, its posted under 'maintinance' as 'hard steering'
your supposed to raise the front wheels up off the ground and disconnect the power steering systems return line, collect the crappy fluid and simultaniously add fresh fluid to prevent air bubbles.
unplug the ignition, crank the engine to operate the power steering pump, add Power Steering Flush and cycle the steering wheel back and forth to totally flush the system.
I had water in my ps fluid and i did this, took me an hour or so and cured my hard steering. Hope this helps
Brian
