I have a problem. My 95 Olds Lss has just started blowing cold air out of the passenger side vents only. I thought it was the passenger side controls but i know they used to work before. The fan blows out the same air on both sides but the driver side is warm/hot, and the passenger side is cold. Does anyone out there have any idea what it could be?
Posted: Sat Jan 14, 2006 12:03 am
Joined: Fri Jun 06, 2003 3:58 pm Posts: 3166 Images:29 Location: Michigan, USA
Do you have the digital climate control module? I know that specifically the Intrigue, they had the exact same problem....the control module needed to be replaced. I'll look into it further...
The answer is yes I do. Some more info for you guys might also help you to help me. It worked perfectly because I tried it when I first got the car. I had it in the shop when my main seal was leaking. When I got the car back, I didn't notice it right away but shortly after that is when it started doing its thing. The blower works perfectly, the speeds are the same but passenger side is cold air (floor, defroster,vents) Everything on the right side is cold and everything on the left side is adjustable and works correctly. I shut off the passenger control, hoping that would work or I assumed that the passenger side controls were working and turned them up as hot as they would go and it did not change anything.
Users browsing this forum: Bing [Bot] and 13 guests
