It is currently Wed Nov 25, 2026 7:20 am
 Page 1 of 1 [ 12 posts ]
PostPosted: Sun Jan 22, 2006 9:03 pm
my car hasnt had any problems until now, its a 3.3L v6 1991 olds cutlass ciera, i went on vacation for a week and started the car when i came back, started up fine. after brushing the snow off of it, about 2 mins of running time the engine just quits, immediate stop, fans and radio still on. now the car will just turn and turn but wont start up, fuel pressure is fine, hovers around 42psi, theres no spark to the plugs. thought it might be the ignition control module, tested along with the 3 coil packs, everything checks out fine, so that left maybe the crank shaft sensor, replaced it, tested the old one after the car still didnt start, old one was fine but now theres a new one in place(better safe than sorry), ruled it down to the engine control module, couldnt test it so replaced it, still wont run, no spark. figured might try replacing the ignition control module for giggles...still no spark, im at a real loss, what else could be wrong?
*brand new ECM,ICM,crank sensor
boy i wish i knew a thing or two about cars...it has to be something stupid just overlooked because all i can think of is a short or open somewhere in the wiring...
PostPosted: Sun Jan 22, 2006 9:17 pm
oh and i forgot i hooked a computer to it and theres no error codes, and the computer was getting readings except for the rpms and a few other things that led to believe that it was the crank shaft sensor to begin with i really dont want to have to take it to a garage after sinking this much time and money to fix it myself
PostPosted: Sun Jan 22, 2006 11:10 pm
Hows the wiring harness going to the crank sensor? Mine corroded pretty bad leading to the failure of the crank sensor... worth checking out. Double check all the connections, maybe something is loose or dirty... Hope that helps
PostPosted: Mon Jan 23, 2006 6:56 am
checked the connection at the crank sensor, voltage at pin D is 10.5 V, voltage at pin C is 5.25v, i thought C is supposed to be ground so im not sure where its getting that extra voltage from, ALLDATA says its supposed to be 10-12 between C and D but between the pins its only 6v because of the drop...how can i trace the problem?
PostPosted: Mon Jan 23, 2006 9:57 am
Maybe I missed it, but no where in there did you mention that you checked your fuses. Did you? Electrical problems are a lot of fun ;-)
PostPosted: Mon Jan 23, 2006 11:06 am
Ok, now the fun part. You have something giving your ground voltage. If there is supposed to be 10-12 volts between D and C, and 10-12 at D, then C must be your ground. Since you have voltage at the ground, you must trace these wires back. Now, you have to have the guts to dig in to the harness. Somewhere you have a short, or 2 bare or cracked wires touching. You will need to find where this is happening. The only way I know how is by a visual check. Start following stuff back, and hopefully it is close. Hope this helps.
PostPosted: Mon Jan 23, 2006 11:40 am
fuses are all fine, and yea i was afraid of having to trace those wires, that was the next thing to do...just have to find time to do it
PostPosted: Wed Jan 25, 2006 1:59 pm
well problems solved before had to take it to the shop...a bad ground on the ICM due to corrosion, even though we had scrubbed it off apparently it took a little more scrubbing to get it to work(we got desprate so decided to scrub the crap outta it) and after a few tries of the engine dying due to all the gas that had flooded the engine it eventually stayed running...thanks for all the help guys
PostPosted: Wed Jan 25, 2006 6:59 pm
Hi autoilliterate, hello everyone,
........ thanks for all the help guys
Thanks for posting back.
PostPosted: Wed Jan 25, 2006 7:54 pm
Good to hear!
PostPosted: Thu Jan 26, 2006 9:45 pm
glad you got your car running....were would i find the computer gound on my car i have a olds also 87 cuttless 3.8 thanks
PostPosted: Thu Jan 26, 2006 10:27 pm
In a different thread.
Users browsing this forum: Bing [Bot] and 13 guests
