It is currently Wed Nov 25, 2026 7:20 am
 Page 1 of 1 [ 11 posts ]
PostPosted: Fri Jan 27, 2006 3:41 pm
My car has a rough idle and if i go right away within a minute of starting the car when i go down a hill or come to a stop it jerks and sometimes shuts off but starts right back up and is fine after that. or if i let the car warm up before i go for about 5 minutes it wont do it either. Now the rough idle is all the time and i did the paper clip trick and i got a code 66 so i baught a shorter belt and routed it without the ac and it still has the same problems. btw my car is a 1992 oldsmobile eighty eight royale brand new pcv valve, plugs , wires , powersteering pump, altinator, coil packs, maf all changed within 5000 miles
if anyone has any ideas what it could be that would be greatly appriciated.
PostPosted: Sat Jan 28, 2006 1:14 pm
now i have a squeeling since this morning coming from one of my pulleys the tensioner can move back and fourth a little so im going to try to replace it today
PostPosted: Sat Jan 28, 2006 6:16 pm
also after the car is warmed up and it stops happening if i pull off the oil cap it starts jerking hard again
PostPosted: Sat Jan 28, 2006 10:01 pm
Hi 92olds88royalle, hello everyone?
........ it stops happening if i pull off the oil cap it starts jerking hard again
Did it start before or after you changed the PC valve?
PostPosted: Sun Jan 29, 2006 8:53 am
it ran before i changed the pcv valve but it still had the rough idle and jerking i changed the pcv valve because in the 3 years ive had the car ive never changed it but when i pulled it out it was still good (i could shake it and you could hear the rattle) and i changed it anyways.
got any ideas??
thanks
PostPosted: Sun Jan 29, 2006 3:37 pm
92olds88royalle wrote:
........ i changed the pcv valve because in the 3 years ive had the car ive never changed it ........
Should be changed according to the Mfrs maintenance schedule. RTFM.
........ but when i pulled it out it was still good (i could shake it and you could hear the rattle) ........
Shaking it shows the check valve is not stuck, nothing else.
........ got any ideas?
We are already working on one.
Since removing the oil filler cap affects the problem, the crankcase is the logical place to look. Both ends of the "Closed" PCV (Positive Crankcase Ventilation) system are the easiest and most probable.
1. Pull the Valve out, leaving the vacuum hose on.
2. Start the engine.
3. Block the end of the valve with your finger.
4. Did you hear/feel the valve move and did the engine speed change? Doesn't tell if the air is metered correctly, only that the valve assembly is working properly.
5. Report back. Might be a wild goose chase, but they are part of troubleshooting.
I generally answer these posts only when I see information that might pertain to the actual problem. Exceptions are when (for everyones benefit) I state why someone elses suggestion, is or, might not be valid, and therefore, a waste of the TOs time.
PostPosted: Sun Jan 29, 2006 6:57 pm
Well my engine wont run without that cover for the pcv valve on you can hear it very loud a vaccum dont know how it works considering its just a plate no hose coming off of it or anything its a vin L engine i cleaned the throttle body and it stopped jerking and stalling but now i have a code 22 maybe this has something to do with why it was stalling before?
PostPosted: Sun Jan 29, 2006 8:39 pm
Well my engine wont run without that cover for the pcv valve ........
All I know is basics. I'm done.
Anyone else?
PostPosted: Sun Jan 29, 2006 8:46 pm
hey norm maybe you would know the answer to this question. does the throttle position sensor sit on the side of the accelerator so when i hit the gas its pushed with the throttle or does it sit on the other side so when i hit the gas it moves to the throttle with a motor or something??
thanks
PostPosted: Sun Jan 29, 2006 10:16 pm
........ does the throttle position sensor sit on the side of the accelerator ........
Sorry, your question is one I might be asking, not answering. Most everyone here knows I'm more comfortable answering questions in mechanical areas, than in electronics.
PostPosted: Tue Jan 31, 2006 11:23 am
The TPS sits on the underside of your throttle body, and moves with the accelerator pedal. It tells the computer when and how much throttle is being applied. Code22 is TPS LOW. You likely need a new sensor, but you can try to adjust it. Do a search for TPS on the message board, and you'll find info on adjusting or replacing TPS sensors.
Users browsing this forum: Bing [Bot] and 13 guests
