It is currently Thu Nov 12, 2026 6:58 pm
 Posted: Wed Feb 01, 2006 11:31 am |
The TPS sensor you replaced could just need adjusting itself. The code 22 never went away, indicating that the TPS voltage is too low. This is resolved by rotating the sensor within its ajustment screw limits. Ideal voltage is 0.4V, but the computer will accept anything over 0.25V.
I had problems with jerking and backfiring, and after a lot of smashing my head, cleaning ignition module contacts and checking all the sensors, it turned out to be a damaged plug wire, leaking over to the next wire, creating a horrible backfire, and jerking when the spark would jump.
 Posted: Thu Feb 02, 2006 11:11 am |
code 22... the only thing that means is TPS low. How did you measure the voltage? At the sensor, or through the computer? These two values COULD be different, if there is a bad signal connection at the ecm. +5V Power and ground connections could be good, but the wire that feeds the computer might be corroded or something.
If at all possible, use an ALDL program to monitor values, becuase reported values from ALDL are exactly what the ECM sees.
skiiirt
 Posted: Thu Feb 02, 2006 12:22 pm |
Joined: Tue Jan 24, 2006 5:33 pm Posts: 13 Images: 28 Location: T6K - T6L
Did you reset the computer after doing all of this?
_________________ skiiirt's Album
2002 Diamond White Aurora 4.0L V8
2004 Onyx Black Bravada - 4200 V6
RIP - 1992 Medium Garnet Red Cutlass Supreme Int.
RIP - 1981 Metallic Blue Cutlass Supreme
RIP - 1981 Metallic White Cutlass Supreme Brougham
 Posted: Fri Feb 03, 2006 8:12 pm |
why do you feel you are getting a code 22? did you try an aldl reader?
btw, i think that if you find out why you are getting a code 22, youll find the coolant sensor problem also. did you check the wire loom for melting and such to the exhaust manifold crossover?
 Posted: Sat Feb 04, 2006 11:50 am |
so what is a code 66?
87Delta
 Posted: Sat Feb 04, 2006 5:31 pm |
Brando wrote: This is due to the refrigerant pressure being low, the computer protects the compressor by disabling the A/C relay and storing a code 66.
Would this cause the A/C Compressor to not kick on? Mine will not kick on anymore when we were testing it, and I thought it was toast, not it may just need recharged?
Sorry to hijack the thread, just want to know...
 Posted: Sat Feb 04, 2006 7:18 pm |
Hi 92olds88royalle, Brando, 87Delta, hello everyone,
87Delta wrote: ........ Would this cause the A/C Compressor to not kick on? ........ Yes. Quote: ........ I thought it was toast ........ It might be. No way to tell without testing it. Quote: ........ it may just need recharged? ........ It may. See my comment on "testing" below. Quote: ........ Sorry to hijack the thread ........ Not a hijack. Those questions were on topic and a welcome contribution to the discussion. Brando wrote: ........ This is due to ........ This is most likely due to ........ Quote: ........ there is mostly likely a leak ........ There is a leak. It's the only way a system can lose refrigerant. Quote: ........ so it should be vacuum tested first. ........
A "gauge set" is used to check for proper operation and to diagnose any problem a system might have.
A "leak detector" is used to find leaks.
A "vacuum pump" is used to remove contaminants from a system that has been opened.
92olds88royalle: As I stated in my response to your email, I only post advice in areas I'm familiar with. Refrigeration is one of those few subjects.
