It is currently Thu Nov 12, 2026 6:26 pm
PostPosted: Mon Mar 06, 2006 11:33 am
A buddy of mine's kid bought an 84 Cutlass V6 and I volunteered to help him get it running. Upon inspection it appears that I have a mess to deal with under the hood. It has a V6 with electronic dualjet. AC has been removed and smog pump has been removed. Right off I found that the oxygen sensor was not hooked up and the PCV valve grommet was toast. Does anyone have a source for a wiring diagram and vacuum hose diagram for this car? And, do you think there's any chance I can get this thing to run OK with the computer controlled carb, but without the smog pump and other emissions stuff hooked up?
PostPosted: Mon Mar 06, 2006 11:42 am
I think it would be tough to get goin without the emissions stuff... There should be a vac. diagram on the radiator support IIRC... I would have the guy invest in a Chassis Manual for the car and I would hook all the smog junk back up. JMHO
