It is currently Tue Nov 24, 2026 2:35 pm
 Page 1 of 1 [ 12 posts ]
 Post subject: Here's a weird one...
PostPosted: Sun Apr 02, 2006 2:30 pm
Ok, this is a new one in my books...
I've been having intermittant service engine soon lights in the past week or so. Very seldomly it will come on at a stop light, and the idle will jack about 500 rpm from normal idle. After 2 or 3 stop lights later, the error is gone, and the light is out. The car has been driving normally, all has been well otherwise.
Twice now, I've pulled out the handy pre-bent paperclip from the glovebox, and plug it in as soon as I stop. There are no codes stored in the ecm. None. Code 12, code 12, code 12 (Diag mode: which means there is nothing stored out of the ordinary).
Does anyone know of any errors the computer would detect, which would dissappear without a re-start, and without documenting a code? Head scratcher! (I love those!) Its so hard to even start to look for a problem when it only happens for a few minutes maybe twice a week, and there are no visible symptoms...
PostPosted: Sat Apr 15, 2006 11:19 am
Images: 8
The "Service Engine Soon" light has been coming "on" in my car after about an hours worth of driving. It doesn't appear again after I turn the engine off and restart it again.
I've just sent away for an Auto XRay EZ read 3000. I'm curious to find out what my shop manual says to do once I see the code. I'm hoping it's a simple fix.
I have an appointment this upcoming Thursday with my mechanic. I'll keep you posted.
PostPosted: Sat Apr 15, 2006 11:08 pm
the problem I've got is that the computer is not documenting a code. If there was one, I can read it quite easily, using my on board diagnostics, or my handy paperclip ;-) Unfourtunately, I am still getting the errors occasionally.
I have a sneaking suspision that the o2 sensor is on its last leg. What (if any) is the procedure for testing an o2 sensor?
PostPosted: Sun Apr 16, 2006 4:31 am
Images: 8
According to my shop manual, the CODE 13 section for your engine 3.8L Vin 3 describes how to test the oxygen sensor.
Circuit Description:
The ECM supplies a voltage of about .45 volts between terminals "D6" and "D7". (If measured with a 10 megaohm digital voltmeter, this may read as low as .32 volts). The O2 sensor varies the voltage within a range of about 1 volt if the exhaust is rich, down through about .10 volts if exhaust is lean.
Test Description:
Numbers below refer to circled numbers on the diagnostic chart.
1. Code 13 WILL SET:
- Engine at normal operating temperature
- Up to 2 minutes engine time after start.
- O2 signal voltage steady between .35 and .55 volts
- Throttle position sensor signal above .55 volts.
- All conditions must be met for about 60 seconds.
2. This will determine if the sensor or the wiring is the cause of the Code 13.
3. In doing this test, use only a high impedence digital volt ohmmeter. This test checks the continuity of CKTs 412 and 413 because if CKT 413 is open, the ECM voltage on CKT 412 will be over .6 volts (600 mV).
Diagnostic Aids:
An intermittent may be caused by a poor connection, rubbed through wire insulation, or a wire broken inside the insulation.
Check For:
- "Poor Connection or Damage Harness" Inspect ECM harness connectors for baked out terminals "D7" or "D6", improper mating, broken locks, improperly formed or damage terminals, poor terminal to wire connection, and damaged harness.
- "Intermittent Test" If connections and harness check OK, "Scan" O2 sensor voltage while moving related connectors and wiring harness, with warm engine running at part throttle in "Closed Loop". If the failure is induced, the "O2 sensor voltage" reading will change from its normal fluctuating voltage (above 600 mV and below 300 mV) to a fixed value around 450 mV. This may help to isolate the location of the malfunction.
Then there's a flow chart on the next page which says to disconnect the O2 sensor, jumper harness CKT 412 to ground, "SCAN" tool should display O2 voltage below .2 volt (200 mV) with engine running. If it does, faulty O2 sensor connection or sensor. If it doesn't, then it proceeds to doing a test of the ECM.
As soon as I get a chance, let me document scan that section for you and send it to you as a PDF file.
I hope this helps.
PostPosted: Sun Apr 16, 2006 12:19 pm
Images: 8
By the way, CKT 412 is the purple connection going to D7 and CKT 413 is tan going to D6 to your ECM.
If the test of your oxygen sensor doesn't turn up anything, let me know if you need the information on testing your ECM.
PostPosted: Mon Apr 17, 2006 9:10 am
excellent! thanks a lot! I will test out the O2 sensor. For the price, maybe a replace is in order anyways, I gaurantee this is the original from the factory. Always good to have explicit diagnostic info here... Thanks again.
BTW, I went for a 10 hour jaunt round trip this weekend, and used some isopropyl to clean the injectors, and the code comes up less often (likely due to the increase in octane?). Nonetheless, it still comes up. Weird that the computer will not document this as an error code though.
PostPosted: Mon Apr 17, 2006 9:19 am
From the way I see it, the more the octane (well, not getting rediculous, like 100) the less likely detonation will occur, so it coulda been detonating?
Not exactly sure, I'm more used to lawnmower engines :lol:
PostPosted: Wed Apr 19, 2006 2:58 am
Images: 27
that o2 is KILLING your gas milage most likely. change it ASAP...check out GMPD for OEM.
AVOID BOSCH!!! 3800 + BOSCH = no go
PostPosted: Thu Apr 20, 2006 10:32 pm
Images: 8
Here's my latest update:
I received my AutoXray scanner today and tried it out. Nice tool!
I found Code 42 was stored in the ECM's Trouble Code History. No other codes came up during the initial scan and surprisingly, the SES light did not come "ON" at all. Funny how it stayed "ON" all the way as I was driving home from work today. :shock:
I took a look at the section in my shop manual and found the location of the C3I module (EST circuit) in my engine compartment. The C3I module that's currently in my engine bears no resemblance to the one that's in my factory parts and illustration catalog. I can't definitely say for sure, but I'll bet it's one of those cheap ones that were meant to last only for a few years or a certain amount of miles. The previous owner, whom I bought the car from about a year and a half ago, didn't want to invest any additional money into it other than to make it reliable for work transportation as he so well-pointed out to me back then. Oh well.
I'll still need to have a continuity check of the wiring harness and an Intermittent Test done. But in any event, I went ahead and bought a new one today, a Niehoff with Magnavox coils. The lady over at Kragen was really cool. She asked how I got her Kragen part number and I told her I got it off from their website. For retail, if you were to walk into the store it would go for like $185. She told me to bring in a copy of the online price ($79) and she would honor it. Major coolness!!!
I'm going to have it installed tomorrow. Wish me luck guys. :o
PostPosted: Fri Apr 21, 2006 10:34 pm
Images: 8
What a day. The good news is the new C3I module and coil pack did the trick. Had the throttle body taken out and cleaned. Cleared the trouble code and started the engine. Wow, what a difference! The idling is smoother and after about an hour's worth of driving, the SES light stayed "OFF".
Now for the bad news. I went ahead and connected my scanner back to the ALDL socket just to double-check everything and then I saw a new trouble code stored in the ECM's history: CODE 39.
Went back to my trusty shop manual and started performing the diagnostic checks. I started with the fuse block and checked the #19 15amp fuse. This fuse "ties-in" with the TCC portion of the the brake switch. No problems there. I then proceeded to do a QDM 3 scan with the engine "off", to check the "high" and "low" positions with the brake pedal. Everything checked "OK" there. By the time I got finished there, it started to get too dark. The final check involves driving my car in "Closed Loop" operation, speed above 45 mph and with the TPS reading above 700mv. Depending whether or not the scan of the TCC reads "ON" and the QDM 3 reads "LOW" during these conditions, will then indicate to me that either the TCC solenoid is bad in the transaxle or the ECM is bad. I plan to do this check at the crack of dawn tomorrow. Stay tuned! :o
PostPosted: Sat Apr 22, 2006 11:35 am
Images: 8
Well, everything checked out OK. I cleared the ECM trouble code history this morning and took my car out for a nice 30 minute drive on the freeway. No CODE 39. The transmission was properly engaging the TCC in the "locked" position and disengaging as it should. Transmission fluid level and color is excellent. No leaks and everything was running smoothly. All electrical connections from the TCC solenoid, brake switch, and the ECM checked out fine. I talked with my mechanic this morning about my data readout on the scanner and he confirmed my belief that it was more likely an intermittent false code that could have been set from any numerous reasons. Nothing major.
I'm cautiously optimistic, however. I'll be monitoring it at least once a week just to be sure. But for the most part, my car is good to go again. :wink:
PostPosted: Mon Apr 24, 2006 1:47 pm
This is funny stuff.
Ok like my problem was the first one described. I had a random light no code no code then i got a code 13. New o2 sensor and the lights on no code just code 12. Took it into shop last week got new exhaust manifold to pipe gasket and bolts and springs, new 2.25" cat welded in and the muffler got welded in. Code comes on at idle but is nothing but a 12. I also got my handy trusty paper clip. This is on the 2.5 motor but still what gives for random lights and no codes?
Users browsing this forum: No registered users and 24 guests
