It is currently Thu Nov 12, 2026 7:34 pm
 Page 1 of 1 [ 10 posts ]
 Post subject: Check Engine Codes
PostPosted: Thu Apr 06, 2006 5:13 pm
88delta88 wrote:
87delta, a lot of codes will throw the computer into open loop mode, therefore burning a LOT of gas. The best idea, is to check your computer for error codes. There might be more than one error code. Let me know (start a new thread if you will)
Now, I understand this, but how in the heck do you check the codes? I don't have access to a friends computer crap anymore. I know exactly where to connect the paperclip thing, but am really confused on how exactly to do it. I did do a search on this forum and found nothing. Also tried searching on the net and found not much of anything. How exactly do you know what code it's throwing out? I understand the lights flashing crap, but I’m scratching my head right now trying to figure it out. Hopefully some of you will know.
Now with my CEL, seems kinda weird. When running the car on the road (well when it was on the road) , if I just lightly use the gas pedal, no CEL would show. On the other hand when I was going up a steep hill and had to get on it to keep going (also moved out out of overdrive, but not likely any relevance, or could be a positioning sensor...) it showed up as soon as I got on the throttle good. Seems kinda odd.
PostPosted: Thu Apr 06, 2006 8:24 pm
Check this out:
http://www.oldsconnection.com/forum/tech_aldl.php
Once you get the code/s I can tell you what they mean...
PostPosted: Fri Apr 07, 2006 2:27 pm
Brando wrote:
Check this out:
Im not exactly sure WTF all that means. How do you know what code it is by just flashes and pauses? Sorry, I'm a pretty dumb person. I have to see it on my own to figure it out. Guess I'll see this weekend what it all means...
PostPosted: Fri Apr 07, 2006 3:12 pm
When the test terminal is grounded (jumper terminal "A" to "B") with the ignition on and engine stopped, codes are displayed in numerical order, always starting with code 12 which indicates that the self-diagnosis system is operating properly. Trouble codes are displayed in the following manner: Code 12 is displayed by one flash, a short pause, then two flashes and a longer pause. Code 12 will be displayed 3 times in this manner, then any additional codes stored will be displayed 3 times each in a similar manner until all codes have been displayed. Once all codes have been displayed. The process will be repeated as long as the test terminal remains grounded.
Just read it over slowly and visualize/think about it.
One flash = 1
Two flashes = 2
Three flashes = 3
..etc..
A short pause inbetween means next digit and a long pause means a new code being displayed.
The code will always be two digits...no shorter and no longer.
PostPosted: Fri Apr 07, 2006 3:19 pm
Thanks Brando...I get it now. You should feel like you've accomplished something. It's hard to get me to understand something. :lol:
Now watch, I won't get any codes out on my ECU :lol:
PostPosted: Sat Apr 08, 2006 7:18 am
A lot of times the Oxygen censor with throw a code when you’re under pressure. It should be about $20 at the parts store, and be careful removing/installing it without damaging the wire. Here are your codes:
Diagnostic Trouble Codes - 1987
Oldsmobile
13 Open Oxygen Sensor Circuit
14 Coolant Temperature Sensor (High Temp Indicated)
15 Coolant Temperature Sensor (Low Temp Indicated)
21 Throttle Position Sensor (Signal Voltage High)
22 Throttle Position Sensor (Signal Voltage Low)
23 Manifold Air Temperature (MAT) Low Temp Indicated
24 Vehicle Speed Sensor (VSS) Circuit
25 Manifold Air Temperature (MAT) High Temp Indicated
32 Exhaust Gas Recirculation (EGR) Circuit
33 Mass Air Flow Sensor (MAF) (GM/SEC High)
34 Mass Air Flow Sensor (MAF) (GM/SEC Low)
41 Cam Sensor Circuit
42 C3-I EST or Bypass Circuit Failure
43 Electronic Spark Control (ESC) Circuit
44 Oxygen Sensor Circuit (Lean Exhaust Indicated)
45 Oxygen Sensor Circuit (Rich Exhaust Indicated)
51 PROM Error
52 CALPAK Error
55 ECM Error
PostPosted: Sat Apr 08, 2006 5:20 pm
Thanks. I'll have to check the codes tomorrow if there is cause the computer has been re-set too many times. Didn't know the cooling fan would come on, though when you do the paper clip thing. I got lucky on that one cause dad was workin under the hood :confused:
PostPosted: Sat Apr 08, 2006 5:24 pm
Ah...yea...the cooling fan comes on.
:lol:
PostPosted: Sat Apr 08, 2006 5:29 pm
:lol:
Oh now you tell me, punk! After my dad coulda lost a hand :lol:
Must be some diagnosis thing I guess.
Edit: BTW this beast is comin home tomorrow, w00t!
PostPosted: Sun Apr 09, 2006 1:21 pm
Code 32, something with the EGR? Can somebody spread some light on this issue?
