It is currently Tue Nov 24, 2026 2:35 pm
 Page 1 of 1 [ 14 posts ]
 Post subject: ticking noise
PostPosted: Wed Apr 12, 2006 3:36 pm
Been awhile since i been on here. I've got a problem, i posted it a looong time ago but never got an answer and wasnt able to find the thread so forgive me for starting a new one because i know you guys hate that.
so here it is...
I replaced my spark plugs, started the car up after each one was installed on the driver side and all was fine.
I decided not to start it between replacing the last 4 on the passenger side because my driveway is uneven and i diddnt trust my bottle jacks. Now im hearing a ticking noise thats relevent with my RPMs, seems to be coming from the passenger side.
At first i thought it was the rotor hitting the inside of the distributer cap but i checked and replaced that and thats not the case. I thought maybe the wires were arcing out because they were so old so i replaced those, diddnt help. It isnt valve chatter. plugs are in tight. I've taken out and replaced all 8 plugs to find any errors about 3 times and still havent figured it out.
this might sound crazy, but does my timing have to be adjusted now to go with the new plugs? It never made this sound before i changed the plugs so im almost certain it is in fact the plugs unless maybe i bumped somthing i wasnt supposed to. Any ideas much appreciated.
:idea:
Brian
1995 Saturn SL2 (SOLD)
PostPosted: Wed Apr 12, 2006 5:23 pm
No, timing isnt affected by changing spark plugs. How are your wires? A damaged boot on a wire can lead to arcing to ground, which in some cases can produce a ticking sound, and the car running generally poor.
You most likely wont be able to see a damaged plug wire, there are usually no visible signs of damage. If they're older wires, buy some new ones and install them. (do one wire at a time, to avoid cylinder mixup).
If you're still racking your brain on locating this ticking after checking the wires, then change your train of thought. How do you know the sound you hear is not valve tick?
PostPosted: Thu Apr 13, 2006 1:43 pm
Turn out the lights. Check your engine in the dark. I suspect arcing. Bad wires. My 72 Caprice had the same problem.
1995 Regency Elite 98
6 bodies in trunk.
PostPosted: Thu Apr 13, 2006 3:40 pm
already replaced the wires, diddnt help. Im not sure valves would just randomly make noise in between changing spark plugs, this cars never even pinged before. Could be a coincidence i guess.
PostPosted: Thu Apr 13, 2006 6:56 pm
ok so i did a little trial and error, i unplugged the last plug from the wire(#8, the one i thought was ticking) of course it diddnt fire, but the ticking stopped. I plugged it back in, unplugged a different plug.. ticking came back. So its definatly somthing with that last cylinder.. got dark out so i gave up early. i guess its back to the drawing board tommoro.
Brian
PostPosted: Thu Apr 13, 2006 7:47 pm
Hi Brianritchie21787, hello everyone,
........ I plugged it back in, unplugged a different plug.. ticking came back ........
Did I read that correctly?
PostPosted: Thu Apr 13, 2006 9:49 pm
haha I'm not sure. If you did would you be asking me? Sorry for the confusing explanation. What i meant to say is that when the plug is not connected to the wire, it stops ticking. I tried swapping plugs, diddnt make a difference. im pretty stumped... my plugs, cap, rotor, and wires are all new. Hope this clears it up a little.
Brian
PostPosted: Thu Apr 13, 2006 9:57 pm
Brian
But is it misfiring? or just "ticking"?
PostPosted: Fri Apr 14, 2006 1:23 am
........ when the plug is not connected to the wire, it stops ticking ........
An exhaust manifold leak sounds somewhat like a ticking lifter, and will disappear along with the spark. If your tick does not get louder with increased engine load, it's not the exhaust.
PostPosted: Fri Apr 14, 2006 11:34 am
runs smooth, just ticks.
I also realized it feels like it lacks more in the higher rpm range then it used to.
Im not sure it gets louder because under load im inside the car, but it does get more consistant and more noticable under higher load.
I'm about to go check my manifolds over right now i'll let you know later tonight. Thanks for your help.
Brian
PostPosted: Sun Apr 16, 2006 6:49 am
........ it does get more consistant and more noticable under higher load ........
Sounds like the same discription.
PostPosted: Wed Apr 26, 2006 8:46 pm
I looked over my exhaust manifolds today, no obvious signs of damage although its a tight spot and its hard to see around the whole header without a mirror and a flashlight.
i noticed a dent on what i think is a fuel rail (figure 1)
Also found i have a small head gasket leak just above the troubled cylinder(figure 2)
think one of these could be the problem?
PostPosted: Thu Apr 27, 2006 8:48 am
1 I dont think thats the fuel rail.
2 That would be a valve cover gasket leak. Head gasket will be under the head.
PostPosted: Thu Apr 27, 2006 10:39 pm
88delta88 wrote:
1 I dont think thats the fuel rail ........
Its an A. I. R. (Air Injection Reactor) pipe. The A. I. R. (smog) pump, blows fresh air through it into the hot exhaust causing the cool oxygen to ignite any unburned fuel before it exits to the atmoshpere.
From the pic, it looks like exhaust gases have been going where they are not supposed to, caused the tubing to rust thru.
I'm guessing an inoperative check valve is the root cause.
The replacement part should be available at your local parts supplier, and they can tell you if the check valve is part of it, or elsewhere.
88delta88 wrote:
2 That would be a valve cover gasket leak ........
And not uncommon in most OHV engines.
Users browsing this forum: No registered users and 24 guests
