It is currently Thu Nov 12, 2026 9:39 pm
 Page 1 of 1 [ 9 posts ]
PostPosted: Thu Apr 13, 2006 7:25 pm
Hello... I'm having a problem with my 1994 Oldsmobile Eighty-Eight. First problem I've had with the car since I bought it about 5 years ago. It started about 6 months ago when I noticed smoke coming from the engine compartment. I hardly ever use the car, so I left it sit for a few months. Now when I try to run it, i have to jump the battery (which was expected), and white smoke continues to come out of the engine. It seems to be coming from the engine block. I've check for oil in the coolant and water in the oil, which I've read would be caused by a blown gasket and could cause white smoke from the exhaust, but not really from the engine. The car doesn't seem to overheat, but I don't let it run long enough to really find out. Also, after sitting for so long, wouldn't the coolant all have leaked out if it was a blown gasket? Any suggestions would be appreciated. I can post a picture of where the smoke is coming from if that may help. Thanks.
PostPosted: Thu Apr 13, 2006 8:48 pm
Hi igalvan55, hello everyone,
........ I noticed smoke coming from the engine compartment ........
Is it possible it's steam? If not, you can eliminate head gaskets, and the rest of the cooling system, as the root cause.
Is there any smoke coming from the exhaust?
........ It seems to be coming from the engine block ........
We need to know exactly where.
........ Also, after sitting for so long, wouldn't the coolant all have leaked out if it was a blown gasket? ........
No.
........ I can post a picture of where the smoke is coming from if that may help.
It would be most helpful.
PostPosted: Sat Apr 15, 2006 11:20 pm
describe the smell of the smoke also, if possible
PostPosted: Wed Apr 19, 2006 2:54 am
Images: 27
Several things are possible, most likely you have a failed intake gasket, furthermore the LIM Gasket either external or internal failure. Also could be the TB Gasket, but that would drip coolant on the crossover pipe.
These cars RARELY RARELY blow head gaskets, not saying its impossible, but the intake manifold gaskets die much more often.
Are you seeing smoke out of the exhaust? Assuming we have a gasket issue, you are most likely seeing steam out of the cracked exhaust manifolds (also a common occurance with the series one manis)
PostPosted: Wed Apr 19, 2006 8:19 pm
Hans wrote:
........ most likely you have a failed intake gasket ........ the LIM Gasket either external or internal failure ........ could be the TB Gasket ........
I'm impressed.
His internet education enables Hans to make a diagnosis without even knowing the symptoms.
Hans wrote:
........ These cars RARELY RARELY blow head gaskets, not saying its impossible, but the intake manifold gaskets die much more often ........
Can this statement do anything other than confuse the OP?
Hans wrote:
........ Are you seeing smoke out of the exhaust? .......
Looks just like the echo I saw on another thread.
PostPosted: Sat Apr 22, 2006 12:49 pm
Images: 27
Regards,
back on topic please :wink:
However in the posters profile it says that he has a V8..We might need a little more info on that.
PostPosted: Sat Apr 22, 2006 1:19 pm
We may need a LOT more info on that. A rare car indeed.
1995 Regency Elite 98
6 bodies in trunk.
PostPosted: Wed Jun 14, 2006 5:11 pm
well, we fixed it with a bottle of head gasket sealant... no more smoke, and everything runs fine. thanks all
PostPosted: Wed Jun 14, 2006 5:21 pm
Glad to hear you got it fixed...what brand head gasket sealant did you use?
