It is currently Tue Nov 24, 2026 2:35 pm
 Page 1 of 1 [ 7 posts ]
 Post subject: Blinker
PostPosted: Tue Apr 18, 2006 12:49 pm
I'm posting on behalf of my friend. He has a 1995 Oldsmobile Cutlass Supreme and his left blinker isn't functioning. The light isn't burnt out, the thing that makes it blink is. Does anyone know where this is located on the car, what the official name for it is, and how he can replace it?
 Post subject: Re: Blinker
PostPosted: Tue Apr 18, 2006 5:54 pm
Hi CodeLabMAster, all,
It's called a flasher, or a breaker. It will be located in the fuse box. It is the big round thing. Any parts store should have it, just take it in and they will match it up. Hope this helps...
EDIT... just thought of this...
Even with the flasher out the bulb should light up. If it doesnt light up, the flasher is not your problem. The fact that it is just the left seems fishy to me, although I do not know how it is wired up. Does the light come on at all? Or does it just not flash?
PostPosted: Tue Apr 18, 2006 6:38 pm
Hi CodeLabMAster, hello everyone,
........ his left blinker isn't functioning. The light isn't burnt out, the thing that makes it blink is .........
andrewk is correct.
If a bulb doesn't light, it's burnt out.
If all bulbs on both sides do not light, the fuse is blown.
If any bulb on one side lights but doesn't flash, another one on that side is burnt out.
If all bulbs on both sides light, but don't flash, it would be the flasher.
If, there is also a problem with the stop lights, the switch might be the cause.
The above should apply to any car with turn signals.
PostPosted: Wed Apr 19, 2006 2:55 am
Images: 27
You have a dead light bulb I would guess
PostPosted: Wed Apr 19, 2006 3:21 am
Is there an echo in here?
PostPosted: Wed Apr 19, 2006 9:03 am
hahaha... blinker fluid. good one hans!
PostPosted: Tue Apr 25, 2006 11:25 pm
Images: 8
CodeLabMAster, give this a shot:
If you are absolutely certain the lamp is good, remove the lamp from the socket and inspect the contacts inside. If you see any kind of hard clay like residue build-up inside, clean it, with a brush or a trusty pocket knife blade, reconnect your lamp and then try it out.
Don't be alarmed if you see this kind of substance. I had this experience once. If, in your inspection, you noticed any clay like substance trapped inside the lamp socket, it's actually a grease film (a corrosion inhibitor) that over a period of time being exposed to the elements will eventually harden and may sometimes interfere with the lamp contacts.
Hope this helps. :o
Users browsing this forum: No registered users and 24 guests
