It is currently Tue Nov 24, 2026 2:35 pm
 Page 1 of 1 [ 6 posts ]
PostPosted: Sat Apr 22, 2006 5:04 pm
Hey guys,
Changed the oil the other day and did checks of the other fluids. I noticed the trans fluid to be darker, but not dark enough to be considered dirty. I've heard a lot of people that swear to never flush the trans fluid in an automatic transmission. They say only change pan fliud and filter. The reason given is that a flush stirs up metal filings and plugs tiny passages and can lead to early trans failure.
I am not sure what to beleive. A shop here in town is offering a new type of trans flush, in which they connect thier machine to a line on the transmission and let the trans pump do the pumping of fluid. This (they say) eliminates the problem described above. I do not know enough on the topic to make an informed decision about to flush, or not to flush my automatic transmission. I would like all new fluid, but if changing the pan fluid 4L at a time (along with filter of course) is enough, I am just fine with that too.
Input?
PostPosted: Sat Apr 22, 2006 5:13 pm
The way I see it you shouldn't have metal shaving in your tranny to begin with. I say get it flushed. But I don't know much on transmissions. All I know is D goes this way *points forward* :lol:
PostPosted: Sat Apr 22, 2006 9:59 pm
Hi 88delta88, hello everyone,
Does it say anything, in your maintenance schedule, about flushing your trans?
........ The reason given is that a flush stirs up metal filings and plugs tiny passages and can lead to early trans failure ........
All metal particles flow to the pan and are kept from recirculation by the filter. If any of them are lodged anywhere else in the trans, it will have already failed.
87Delta wrote:
........ The way I see it you shouldn't have metal shaving in your tranny to begin with ........
Metal particles begin to collect in the pan from the time the trans is first used and are the reason the maintenance should be done by a qualified trans tech.
The overall condition of the trans can be determined by "reading" those particles, and the owner can then be advised of potential problems.
Just a little insight into why I rebuild my own transmissions, but have the PM done by my local trans shop.
Then again, it has been well documented, by four different people, that I don't know WTF I'm talking about.
PostPosted: Sat Apr 22, 2006 11:22 pm
I've heard this subject argued both ways, but the way I see it ... your transmission shouldn't need a complete "flush" unless your fluid is in unusually bad condition. If the fluid is in decent condition, a complete flush would provide little to no benefit. Just keep up with the normal maintenance schedule and it should be fine.
PostPosted: Sun Apr 23, 2006 12:34 am
Hi 73Delta88, All,
I've heard this subject argued both ways ........
One side knows what they are talking about, and the others are repeating a sales pitch and/or something off the internet.
Arguments in favor, will make perfect sense to anyone with little knowledge of automatic transmissions. Those against, will usually be those that actually know the subject.
........ Just keep up with the normal maintenance schedule and it should be fine.
Yep.
PostPosted: Sun Apr 23, 2006 2:59 am
Images: 8
I don't have a good longevity record with my former 86' Ninety-Eight Regency and 91' T-bird transmissions. Each one after a transmission flush.
I service the transmission every 6 months now, irregardless of fluid cleanliness, appearance quality, and amount of mileage driven within that time span. I drop the transmission pan and dump the fluid and change the filter and pan gasket and replenish it again with new Dexron -- just like you do.
I maybe crazy for doing it so often, but I can definitely say that my transmission is clean and very reliable. I figure with as much fluid and filter changes I've done so far with my transmission, I probably have enough clean fluid circulating inside to be equivalent to one done with a flushing machine.
When I look back on my previous vehicle transmission failures, I always have this dark thought of possibly picking-up and circulating someone else's transmission contaminants, irregardless of how well the operator was maintaining his flushing equipment or however unfounded my belief system is about flushing.
Every now and then, I've often thought about another alternative to increasing the longevity of my transmission fluid by means of installing a high performance transmission cooler. I've been looking around every so often to see if I could find the right one that would work for my car.
Users browsing this forum: No registered users and 24 guests
