It is currently Tue Nov 24, 2026 2:35 pm
MysterHK
 Posted: Wed Apr 26, 2006 10:17 pm |
Last weekend after the EST problem was fixed, I decided it was time to rotate my tires.
Prior to that, the ride was ever so slight on the rough side, but not really dramatically noticeable. So just out of curiosity, I decided to have the balance checked on all four tires. The rear tires along with the front-left tire were off about a 1/4 of an ounce each, but the right-front tire was off a complete full ounce. Once the balance was corrected, the improvement was dramatic and the car seemed to ride on air. But in the past couple of days as I was taking on passengers in the front seat, I would notice a slight wobbly sensation that would just happen intermittently then disappear. I kept thinking to myself that it couldn't possibly be the alignment, due to the fact that when I replaced the front struts and had four brand new tires installed, I had the alignment done at the same time. This was about two years ago. I've been very conscientious about my tire rotation schedule and this is like the fourth one, since. All four tires have a nice even tread wear pattern and I don't see any evidence of blistering like you would normally see, if the alignment was really screwed.
In any event, I've decided to have the lateral and radial runouts on all four wheels checked as well as the wheel stud runouts. I've always wanted to see how the dial gauges are placed when they do this. It should be pretty fun to watch. I'll keep you guys posted.
By the way, if any of you guys have ever completed this check yourselves or seen this check physically done in real life, could you let me know what I can expect to see when I have mine done? Thanks in advance.
_________________ If everyone can easily acquire or obtain it, it's not worth the trouble of trying to own it for me.
 Posted: Thu Apr 27, 2006 3:58 am |
MysterHK wrote: Last weekend after the EST problem was fixed ........ What was you EST problem? MysterHK wrote: ........ couldn't possibly be the alignment ........ had the alignment done ........ about two years ago ........
After two years, your alignment, has probably deteriorated due to normal component wear.
No comment, on the rest of your post.
Norom
MysterHK
 Posted: Thu Apr 27, 2006 9:06 pm |
EST is just a short abbreviation for Electronic Spark Timing, Norm. That's what Code 42 points to if it ever comes up in the ECM's trouble code.
As far as the alignment goes, I guess I'm better off being safe than sorry. I'll have that checked as well. Thanks.
 Posted: Thu Apr 27, 2006 9:39 pm |
MysterHK wrote: EST is just a short abbreviation for Electronic Spark Timing ........
What was the nature of the problem, the cure, and how is it related to this thread?
Norom
 Posted: Thu Apr 27, 2006 10:58 pm |
Hi Norm, MysterHK, all,
88 Coupe wrote: MysterHK wrote: EST is just a short abbreviation for Electronic Spark Timing ........ What was the nature of the problem, the cure, and how is it related to this thread? Norom
I believe he is referring to his subdiscussion on this thread...
http://www.oldsconnection.com/forum/vie ... ght=#14805
Norm, I see you have an intermittent problem with your keyboard... sometimes when you press "o" is adds a "m" after it...
 Posted: Thu Apr 27, 2006 11:39 pm |
andrewk wrote: ........ I believe he is referring to his subdiscussion on this thread ........ Thanks, I didn't connect the two. andrewk wrote: ........ you have an intermittent problem with your keyboard... sometimes when you press "o" is adds a "m" after it.
Really?
 Posted: Fri Apr 28, 2006 10:20 am |
MysterHK wrote: Thanks, andrewk! You rock, man! Nice to meet you, too.
No problem... Welcome to TOC!
Norm....I was mistaken... its the "r" key... it adds the "o" sometimes...
