It is currently Thu Nov 12, 2026 11:09 pm
PostPosted: Sun Jun 25, 2006 9:38 pm
Images: 1
with DIS and TBI by car stalled and sputtered in gear after finally figuring i should have it checked when the fuel injector stopped working or was blocked i self diagnosed the problem and found codes 22 and 34
well, replaced those two items and then it seems to idle far too low and stalls, however runs fine when rpm is running
any suggestions how to modify air and fuel mixture without modifying idle stop screw?
should i check to see if the TPS is adjusted properly or just perhaps is it the fuel pressure regulator?
i cleared the codes and checked it again but got no errors
1988 Cutlass Calais 2.5L
PostPosted: Sun Jun 25, 2006 10:42 pm
Hi Philosophic,
Please post background information on your problem. Members are not mind readers, and in order to help, we need to know background on said problems. It's good, however, that you are posting different threads on different problems, alot of guys don't do that.
Regards,
