It is currently Wed Nov 11, 2026 9:32 pm
 Post subject: Overheating?
PostPosted: Fri Jun 30, 2006 1:45 pm
Images: 1
1966 Olds 442 with a 400 BB that has had major rebuild with plenty of upgrades. Problem is is that the car after running for sometime (driving. it seems to not overheat on idle) the car will start spitting out antifreeze from the overflow hose. Im not seeing any oil in antifreeze or vice versa. Ive just replaced the thermostat with a lower temp (160) higher performing thermostat....still getting the same issue. Temp gauge is reading 170 (could be faulty). Any ideas? Looking to go with a higher performance water pump but i just noticed that the radiator cap isnt as snug as it should be...could this be the cause? Newbie to the land of Olds so any help would be appreciated.
PostPosted: Fri Jun 30, 2006 2:52 pm
Rad caps are cheap, that would be a good start. And just FYI, just because there is no oil in water, or vice versa, doesn't mean compression isn't leaking into the cooling system. Do a compression check. Also do a radiator pressure check. Watch for falling pressure readings.
1995 Regency Elite 98
6 bodies in trunk.
 Post subject: Re: Overheating?
PostPosted: Sat Jul 01, 2006 1:23 am
Hi hrazor35, hello everyone,
........ with a 400 BB ........
Yes, an Olds 400 would be a BB.
........ major rebuild with plenty of upgrades ........
If it was done right, it should not overheat.
........ spitting out antifreeze from the overflow hose ........
Without further evidence, there is no reason to assume a higher than normal temp.
........ Temp gauge is reading 170 ........
You have your answer, it's not overheating.
........ the radiator cap isnt as snug as it should be ........
And you have identified the cause of your coolant loss.
RednBlackCutlass wrote:
Rad caps are cheap, ........
Make sure it's the correct one for your application, and that the mating surface in the filler is clean.
