It is currently Sun Nov 15, 2026 2:06 am
 Posted: Tue Jul 18, 2006 5:02 pm |
Not familiar with the EASE software, but am familiar with PC/car diagnostics.
What type of cable is used with this setup? Does the computer end have a 9-pin serial or a USB type end on it? If serial, can you verify that the serial port on the laptop (i am assuming you are using a laptop) is turned on and live?
If you are using a USB to Serial converter, it may conflict with the program, depending on how it was written, and how it addresses the serial port. In this case, try a different laptop, one with a built in serial port.
In all likelyhood, there is nothing wrong with your cable, or the car. It has to be in the configuration of the computer and software. Sorry I cant be of more help, maybe a better description of the exact problem is in order?
 Posted: Tue Jul 18, 2006 5:58 pm |
It's what is sometimes called OBD 1.5, used on GM cars from 94-95 it has an OBD II connector as you mentioned, but reads as OBD I. So your scan tool seems to be doing the correct thing, reading codes in ALDL format...I have no idea why it wouldn't work.
I don't see why you couldn't contact the company through HERE though...or have you already done that?
edit....oh, I see....
Quote: Effective March 1, 2006 EASE Diagnostics customers with products older than one year will be charged for technical support per incident.
 Posted: Fri Jul 21, 2006 10:13 am |
If it is ALDL, using a new style connector, have you tried winALDL? Its a free program, and if it can decypher what is happening, then you can start to make some assumptions. Sounds like your program is having some problems. If the ecm is running in the car, its hard to think it might be the car's fault.
Do you have the means to try another laptop? Doesnt sound like the problem, but sometimes programs run differently on different computers.
