It is currently Mon Nov 09, 2026 6:08 pm
 Posted: Sun Aug 20, 2006 8:14 pm |
roadrunner54177 wrote: ........ I looked at the fuses under the dash........
Did you look at them, or did you check them?
 Posted: Mon Aug 21, 2006 8:39 am |
are there circuit breakers on a 72? Definately sounds like something simple, since all your windows died at once. Definately check the fuses with a multimeter, and check the breakers too (if applicable).
 Posted: Mon Aug 21, 2006 6:15 pm |
88delta88 wrote: are there circuit breakers on a 72? Fuses only. Quote: ........ check the fuses with a multimeter ........
Or a test light.
 Posted: Mon Aug 21, 2006 10:32 pm |
roadrunner54177 wrote: ........ checked them today ........
You have power at the fuse. Next step is to check for power at the switch.
 Posted: Tue Aug 22, 2006 9:34 pm |
roadrunner54177 wrote: what is the best way to take the switch off?
Remove the door panel. Second best, is to carefully pry it out.
 Posted: Thu Aug 24, 2006 7:28 pm |
Happy I could help.
