I first read about butanol in the columbus dispatch. It was about a chem phd from westerville ohio named Ramzy (po box 15, 43004) who patented a two clostridium process and had built a small pilot plant. He is looking at dairy waste as a source of food for the bacteria. unlike yeast, the bacteria can digest complex carbohydrates and other stuff )from there I just happened to find out about approx 40 gal of butanol in a surplus depot.
It was a bit of a leap of faith. I first tried it in an old lawn mower. It worked perfectly. I tried it in a string trimmer but it would not mix in the 2-cycle oil until i put in some gasoline. it ran fine but butanol removed the softening agent in the vinyl fuel line and it needed replaced.
with no sensitive materials in the chevy system to worry about I let the car run down to empty and filled up on butanol and ran the rest of the fuel through it. no problems.
of all of the chemicals I can get for free, n-butanol is in the least supply. That is why I researched gasoline composition and learned how to mix my own from the other chemicals.
Wikipedia has info on butanol prod:
http://en.wikipedia.org/wiki/Butanol_fuel
The bacteria can be ordered but I have not done so yet. Apparently there are genetically improved strains at superlative expense. I will eventually buy what I can afford and improve the strain myself. I work in a research lab with lots of people around to help me and every bit of the necessary bacteria culture equipment is available.
Rather than going into the process myself, I would rather send the powerpoint presentation that ramzy sent to me if I may. Also, if anyone wants to make ethyl, I can give lots of advice about that. There is a lot of good cheap technology that can go into improving the process of making ethyl fuel. Remember that making moonshine is illegal so add your denaturant at the beginning of the batch.
I'll gather the butanol process info and post on the appropriate forum asap.
Russ
Mongo just pawn in gamo of life
