It is currently Wed Nov 11, 2026 9:00 pm
 Posted: Thu Aug 24, 2006 9:33 pm |
roadrunner54177 wrote: ........ gas pedal has 2 cables connected to it, one is broken ........
It's the Kickdown cable for the original TH350 trans. 400 kickdown was actuated by a switch at the gas pedal. If it has the TH400 that matches your 455, it's not broken, it's disconected.
 Posted: Fri Aug 25, 2006 10:34 pm |
roadrunner54177 wrote: how can I tell which trans it is? http://www.oldsconnection.com/forum/tech_trans.phpOlaf wrote: ........ manifold vacuum? 88 Coupe wrote: ........ 400 kickdown was actuated by a switch at the gas pedal ........
Sorry, that's a 12V electric switch.
 Posted: Sat Aug 26, 2006 4:18 pm |
Olaf wrote: ........ the vacuum sucked tranny fluid into the crankcase .........
I don't know anything about trannys. Is that possible? Please explain how.
In vacuum modulated automatics, trans fluid can be sucked into the combustion chamber, via the manifold, through a leaking diaphragm in a vacuum modulator. It goes out the tailpipe, in the form of smoke.
 Posted: Thu Aug 31, 2006 3:48 pm |
88 Coupe wrote: Olaf wrote: ........ the vacuum sucked tranny fluid into the crankcase ......... I don't know anything about trannys. Is that possible? Please explain how.
If you can't explain it, say so.
 Posted: Fri Sep 01, 2006 3:23 pm |
Olaf wrote: ??? Looks like you're quoting yourself, quoting me.
Yes, and in it, the question was asked a second time.
Here it is a third time: How is that possible?
