 Posted: Tue Oct 03, 2006 8:24 am |
dblack3000 wrote: I was reading on another car site about this guy who, just before winter sets in, sprays WD-40 all over the underbody of his car. He claims that it does a good job of keeping that dreaded road salt from there, as well as water--which kind of makes sense to me (WD-Water Displacement). My question is have any of you tried doing it, and wouldn't it have the potential to mess certain things up (e.g. catalytic converter) if you spray it on there.
It shouldnt hurt anything, but it will wear off pretty quickly if you drive alot. Never tried it.
 Posted: Wed Oct 04, 2006 9:12 am |
After your post dblack, I was interested. Looked the name WD-40 up. Never thought it would take them 40 tries to get it right
Why not buy a couple cans of underbody rubberised coating and do it right? The salt wont penetrate through asphault. The cost is minimal if you are concerned about corrosion.
dblack3000
 Posted: Wed Oct 04, 2006 10:57 pm |
Joined: Mon Jun 19, 2006 1:16 am Posts: 52 Location: Long Island, New York
88delta88 wrote: After your post dblack, I was interested. Looked the name WD-40 up. Never thought it would take them 40 tries to get it right  Why not buy a couple cans of underbody rubberised coating and do it right? The salt wont penetrate through asphault. The cost is minimal if you are concerned about corrosion.
Is it easy to do the undercoating myself? My main concern is not to screw anything up down there, especially my catalytic converter.
 Posted: Thu Oct 05, 2006 2:29 am |
dblack3000 wrote: I was reading on another car site about this guy who, just before winter sets in, sprays WD-40 all over the underbody of his car ........ That would have to be a lot of WD-40. There has to be more to it. Please post the link? dblack3000 wrote: ........ He claims that it does a good job of keeping that dreaded road salt from there ........ How does it do it? dblack3000 wrote: ........ as well as water--which kind of makes sense to me (WD-Water Displacement) ........ 1) Where does any water accumulate, that WD-40 could displace it. 2) How can WD-40 displace anything, after it has evaporated? dblack3000 wrote: ........ (e.g. catalytic converter) if you spray it on there. If it gets inside it, maybe. If it can get inside, the cat already has a problem. Spraying it on the outside will do nothing but clean its exterior. http://fanclub.wd40.com/Members/pdfs/WD ... esList.pdfNote the disclaimer at the top. dblack3000 wrote: Is it easy to do the undercoating myself? ........ Yes. dblack3000 wrote: My main concern is not to screw anything up down there, especially my catalytic converter ........
Just the opposite. Any undercoating near the cat, is in danger of being cooked, if not actually ignited.
dblack3000
 Posted: Mon Oct 23, 2006 7:31 am |
Here it is--http://autos.groups.yahoo.com/group/OldsmobileDelta88/message/2634.
 Posted: Wed Oct 25, 2006 10:53 pm |
It’s a bit of a stretch from the original subject,.
http://autos.groups.yahoo.com/group/Old ... r=1&tidx=1
to this one.
Rhino Guy wrote: I live in North Carolina where they don't use salt at all ........ The subject was salt damage to brake and fuel lines. Rhino Guy wrote: ........ Lately we don't even need sand since global climate change keeps us above freezing all year ........ Not even sand? Global climate change? Rhino Guy wrote: ........ And if it does snow we just stay home for a day until it melts! ........ It doesn’t snow, but if it does, the whole state shuts down for a day? Rhino Guy wrote: ........ However, December through March is the monsoon season ........ Monsoon = rain? Sounds like where I am. Rhino Guy wrote: ........ So every November I crawl under all the cars …….. and spray WD-40 on all the metal I can see ........ Bare metal? Rhino Guy wrote: ........ and the stuff does help keep rust down ........ Placebo effect? Rhino Guy wrote: ........ It slowly evaporates and must be replaced every fall ........ That slowly? Rhino Guy wrote: ........ I buy the gallon jug and ruin a perfectly good garden sprayer …….. Ruined? By spraying a lubricant/preservative? Rhino Guy wrote: ........ $20 is dang cheap insurance.
I’ll pass. Especially after visualizing the operation and the mess it would create.
dblack3000: Thanks for the link. It did answer a question, I had, about using stainless steel brake lines on restorations.
 Posted: Fri Oct 27, 2006 8:24 pm |
What kind of oil evaporates?
 Posted: Fri Oct 27, 2006 8:27 pm |
I dunno....I will agree that the dirt will attract water and will cause rust spots if not cleaned regularly...especially if you live in such an area where they use salt on the roads
That's why you should run the car through the car wash, even during the winter, and choose the wash with underbody cleaning.
 Posted: Sat Oct 28, 2006 5:17 am |
Hi TJM, hello everyone,
88delta88 wrote: What kind of oil evaporates? I don't know of any. Brando wrote: ........ and choose the wash with under body cleaning ..........
That's the second choice. There is no third.
But what do I know, last time it snowed here was in 1947.
TJM
 Posted: Mon Oct 30, 2006 10:19 am |
Thanks for the welcome!
Technically speaking, EVERYTHING evaporates at a given temperature. But I'll not go into feezing and boiling points of high-school chemistry because I never took chemistry and I feel that, with that said, it's self-explanitory.
As evidence, when you spray WD-40, how long does the surface(s) stay wet? If it doesn't stay wet FOREVER then something is evaporating. WD-40 contains 45-50% Aliphatic Petroleum Distillates, defined on their MSDS Sheets as Stoddard solvent with an evaporation rate of 0.1 - whatever that means. But given that it does, in fact, have an evaporation rate, we must conclude that it does evaporate.
It's true that if the surface stays oily then rust is prevented but we all know the effects/benefits of WD-40 are but temporary.
Tom
 Posted: Tue Oct 31, 2006 12:21 am |
Which parts actually apply to the topic?
TJM wrote: ....... Technically speaking ........ Interesting phrase. Normally, a good sign that a "red herring" will follow. TJM wrote: ....... everything evaporates at a given temperature ........ OK. At what temperature does oil evaporate? TJM wrote: ....... But I'll not go into freezing and boiling points of high-school chemistry because I never took chemistry and I feel that, with that said, it's self-explanatory ........ Self-explanatory, or, that it is not relevant? TJM wrote: ....... As evidence, when you spray WD-40, how long does the surface(s) stay wet? If it doesn't stay wet forever then something is evaporating ........ Did anyone say WD-40 does not evaporate? TJM wrote: ....... WD-40 contains 45-50% Aliphatic Petroleum Distillates ........ ........ Stoddard solvent ........ ........ with an evaporation rate of 0.1 - whatever that means ........ Like gasoline? Is gasoline oil? TJM wrote: ....... But given that it does, in fact, have an evaporation rate, we must conclude that it does evaporate ........ Yes, Stoddard solvent evaporates at a far quicker rate than lubricating oil. TJM wrote: ....... It's true that if the surface stays oily then rust is prevented ........ Yes, but if there is WD-40, how is the surface oily? TJM wrote: ....... but we all know the effects/benefits of WD-40 are but temporary. Few people realize how temporary. The point has already been made, several times. Once in this thread on TOC: 88 Coupe wrote: ........ WD 40 is a solvent, not a lubricant, and the cleaning should be followed up with silicone spray for lubrication ........
