 Page 1 of 1 [ 9 posts ]
PostPosted: Thu Oct 19, 2006 10:59 pm
I have had some recent problems and would appreciate any advice.
1st problem-about 45 seconds after start-up, strange rattling noise comes from what sounds like the exhaust system-possibly CAT CONVERTER, any advice?
2nd problem-after about 45-60 minutes, occasional backfire like sound (thud, bang, boom type noise) occurs around 2000 rpms during acceleration.
3rd issue-what size of muffler inlet/outlets could I use to relieve excessive backpressure- 2.5 inches diameter or 3, I dont know cause I cant get under the car conveniently.
PostPosted: Fri Oct 20, 2006 12:04 am
Hi snipes1129, hello everyone,
........ rattling noise comes from what sounds like the exhaust system-possibly CAT CONVERTER ........
A muffler shop can probably listen to it, and tell you in a few seconds. If they need to inspect it visually, it would take a few seconds after it is in the air.
Either way, the diagnosis will be accurate and you will hear the cost of the repair at the same time.
........ what size of muffler inlet/outlets could I use to relieve excessive backpressure ........
You have several options. That same muffler shop will explain them to you.
........ after about 45-60 minutes, occasional backfire like sound ........
It may or may not be related. Fix the exhaust first.
PostPosted: Fri Oct 27, 2006 1:03 pm
Cats are not prone to rattle on the Aurora but it does sound like the heat shield is loose.
Exhaust upgrades for the Aurora can be seen HERE
And the backfire could be anything from the cat to a bad fuel pressure regulator to bad plugs and/or wires.
PostPosted: Sun Oct 29, 2006 11:03 pm
TJM wrote:
Cats are not prone to rattle on the Aurora ........
Does that mean we should eliminate it as a possible cause?
TJM wrote:
........ but it does sound like the heat shield is loose ........
If so, would it wait 45 seconds before it started to rattle?
TJM wrote:
........ Exhaust upgrades for the Aurora can be seen HERE ........
Which of them addresses his question?
TJM wrote:
........ the backfire could be anything from the cat to a bad fuel pressure regulator to bad plugs and/or wires.
Which one do you recommend replacing first?
PostPosted: Mon Oct 30, 2006 8:46 am
I'd drop in a 455. :D
PostPosted: Mon Oct 30, 2006 10:38 am
LMAO Norm - I feel like I'm in elementary school and my teacher is giving me a hard time about incomplete answers :wink:
continue reading the sentence.
Varying rates of expansion. A visual/physical inspection should be performed
That question would be best asked of those who have completed exhaust upgrades in that thread
Ensure that your plugs and wires are in good shape, verify no vacuum leaks (the PCV valve and tubes as well as intake bolts are expecially prone). Establish a good baseline before replacing parts.
GraveReaper0 - I think the engine bay may be a little small for a 455 implant :lol:
Tom
PostPosted: Tue Oct 31, 2006 7:10 pm
TJM wrote:
continue reading the sentence ........
I did, before I responded. Does that mean you are not able to answer the question?
TJM wrote:
Varying rates of expansion ........
The cat, yes. The shield, no.
TJM wrote:
........ A visual/physical inspection should be performed.
Inspection/diagnosis, by a muffler shop, was already suggested as a first step.
TJM wrote:
That question would be best asked of those who have completed exhaust upgrades in that thread ........
He will get far more information from the muffler shop that was already suggested.
TJM wrote:
Ensure that your plugs and wires are in good shape, verify no vacuum leaks (the PCV valve and tubes as well as intake bolts are especially prone). Establish a good baseline before replacing parts .........
Wasn't it already suggested that he deal with the exhaust first, then deal with the second problem, if, it still exists?
TJM wrote:
........ GraveReaper0 - I think the engine bay may be a little small for a 455 implant
Depends on his budget. It has already been covered here,
PostPosted: Wed Nov 01, 2006 3:26 pm
Sorry for not responding more directly - Cat maybe, Shield no
But doesn't everything expand and contract at diferent rates? It could just be road-kill dangling under the car; but then again, road-kill would probably not "rattle" but make more of a bumping sound as it flapped in the undercar turbulence. Of course dangling road-kill would not likely be temperature or time sensitive but only MPH sensative. However, if the road-kill was left long enough to decompose then the bones might "rattle". What do you think Norm?
Sorry for the misunderstanding - that was in response to your quoted question Norm.
Yes. But rather than say nothing or "I don't know" I figured a steer in the direction of those who have done it might help provide valuable input.
possibly, If they have done a late-model North* G-platform.
In my experience with the Aurora and IMHO, unless the exhaust system's plumbing is compromised, plugs and/or wires are the most likely cause of the backfire. There was no indication in the original post regarding a compromized exhaust system or a clogged cat, only the possibility of a rattling cat shield (or road kill). If snipes1129 returns with further information/confirmation then further diagnostics can be ascertained. Unfortunately, it seems unlikely snipes1129 will return
I bet you are a glass-is-half-full kinda' guy
PostPosted: Fri Nov 03, 2006 4:38 am
Hi Everyone:
I quietly fixed his first childish mess so I could read it. He did not take the hint.
He wants me to complain about his changed posting style because he did not like my answer to his own complaint. He hopes to use it against me, because he does not know the difference.
Actually, I've found cleaning his up is easy. All I have to do is look for any [color= red] and replace them with [quote= "TJM"] ........
Find all the [/color] and replace them with ........ [/quote]
Delete everything else on the page, and start composing.
Quicker and easier than the normal way I do it.
TJM wrote:
........ Sorry for not responding more directly - Cat maybe, Shield no ........
The question called for a yes or no answer.
TJM wrote:
....... The shield, no ........
So you are saying, a loose part will not start rattling until 45 seconds after the car is started?
TJM wrote:
........ What do you think ........
I think you are immature.
TJM wrote:
........Sorry for the misunderstanding - that was in response to your quoted question ........
The reason for the misunderstanding, was: Your response had nothing to do with any question I asked.
TJM wrote:
........ rather than say nothing or "I don't know" I figured a steer in the direction of those who have done it might help provide valuable input. ........
If you do not know anything about the subject, why did you respond?
Do you think no one here has done any exhaust work?
TJM wrote:
........ possibly, If they have done a late-model North* G-platform ........
Can you explain the reasoning behind that statement?
TJM wrote:
........ In my experience with the Aurora ........ unless the exhaust system's plumbing is compromised ........
Wasn't he already advised to check the exhaust, first?
Am I repeating myself?
TJM wrote:
In my experience with the Aurora ........ plugs and/or wires are the most likely cause of the backfire .........
Most likely? Only on Aurora?
TJM wrote:
........ There was no indication in the original post regarding a compromised exhaust system or a clogged cat ........
Did anyone say there was?
TJM wrote:
........ only the possibility of a rattling cat shield ........
Which a good muffler shop might repair in a couple of minutes, for free. Or, if there is actually an exhaust problem it could be dealt with, at that time.
TJM wrote:
........ I bet you are a glass-is-half-full kinda' guy ........
And I bet you are a brain-is-half-full kinda' guy.
Users browsing this forum: Bing [Bot] and 16 guests
