 Posted: Fri Nov 03, 2006 6:09 pm |
Goodday everyone!
I am having a strange problem, seemingly made worse by the recent cold temperatures around here in the last week.
The car runs like a top, having no driveability problems because of the "ghost code", but really would like to get to the bottom of it.
After warm-up, (it doesnt happen all the time) about 10 minutes of in town driving, the check engine light comes on, and stays on till I shut off the vehicle. Upon starting again, the light is gone. I check the codes with my trusty paperclip, but nothing is ever there.
The O2 sensor is the original from 1988. I am going to replace it due to age and mileage anyways, but wonder if an O2 sensor problem would be recorded into ECM's memory, or if it dissapears upon shutting off the ignition.
For proper verification, I could use my ALDL computer, but I need to have the code showing at the same time I fire up the dash PC and connect all the cords (and that is never convinient when the light is on).
Anyone else ever experience a "ghost code" on thier car? Its so frustrating, because I'll only ever be able to catch it while the error is present, and that is impossible to predict!
 Posted: Sat Dec 02, 2006 1:50 pm |
Hex wrote: Could you define or describe what you mean by a "ghost code" ?
thanks Hex 88delta88 wrote: After warm-up, (it doesnt happen all the time) about 10 minutes of in town driving, the check engine light comes on, and stays on till I shut off the vehicle. Upon starting again, the light is gone. I check the codes with my trusty paperclip, but nothing is ever there.
Wierd, huh?
 Posted: Sun Dec 03, 2006 3:38 pm |
Yeah, mine's still on quite frequently. Havent had the time, or the willpower to go outside and probe around (its very colddddd!).
Something tells me changing the O2 sensor will solve it, and should be done anyways, since its the original from stock.
87Delta
 Posted: Sun Dec 03, 2006 4:21 pm |
88delta88 wrote: Something tells me changing the O2 sensor will solve it, and should be done anyways, since its the original from stock.
Good luck with that. I got one to put in, but have been unsuccessful. I was literally crouched on the engine in the engine bay  Course, I never have the right tools for the job.
 Posted: Sun Dec 03, 2006 5:47 pm |
Hmm...O2 sensor didn't take me long at all from what I recall.....
 Posted: Mon Dec 04, 2006 4:20 pm |
looks like a job better done when the engine is cool.
Does anyone know if the oxygen sensor from a '90 3800 is similar to the sensor on my 88 3.8L? I know they look identical, and the one in my '90 is shiny-new. Looks to have JUST been replaced. Might I be able to save a few $$$ and use the one from the parts car?
 Posted: Mon Dec 04, 2006 6:06 pm |
88delta88 wrote: looks like a job better done when the engine is cool.
Does anyone know if the oxygen sensor from a '90 3800 is similar to the sensor on my 88 3.8L? I know they look identical, and the one in my '90 is shiny-new. Looks to have JUST been replaced. Might I be able to save a few $$$ and use the one from the parts car? Quote: Oxygen Sensor: Service and Repair The following procedure should be performed with engine temperature over 120°F, otherwise the oxygen sensor may be difficult to remove. 1. Disconnect battery ground cable. 2. Disconnect oxygen sensor electrical connector, then remove sensor. 3. Reverse procedure to install. Torque sensor to 30 ft. lbs. Replacement sensors should have a special anti-seize compound applied to threads. If a replacement sensor is lacking anti-seize compound or original sensor is to be reinstalled, coat threads with suitable anti-seize compound.
They are the same sensor.
 Posted: Tue Dec 05, 2006 10:12 am |
Sweeeeeet!
