 Page 1 of 1 [ 13 posts ]
PostPosted: Sat Nov 04, 2006 1:29 am
The 3.3 liter motor won't start. I replaced the head gaskets six months ago, but never started the car then. How to diagnose this ?
PostPosted: Sat Nov 04, 2006 1:31 am
Also I found a wrecked 40,000 mile '92 with the 3.3 V6 motor. Can the '92 four speed O/D transmission swap into my '89 ?
PostPosted: Sat Nov 04, 2006 5:35 am
TimKeith wrote:
The 3.3 liter motor won't start. I replaced the head gaskets six months ago, but never started the car then ........
http://www.oldsconnection.com/forum/vie ... hp?p=11914
http://www.oldsconnection.com/forum/vie ... ght=#11862
http://www.oldsconnection.com/forum/vie ... hp?p=11915
http://www.oldsconnection.com/forum/vie ... hp?p=14861
http://www.oldsconnection.com/forum/vie ... hp?p=14965
We appreciate the many updates you've provided, not to mention all those thanks you included.
TimKeith wrote:
How to diagnose this?
Take it to someone who has the needed diagnostic tools, and knows how to use them. Be prepared to tell them everything you did, or did not do, regarding your head gasket diagnosis and replacement.
If you cannot do that, start by checking the oil, coolant, and fuel levels.
If they are where they are supposed to be, tell us if that "new" starter is doing what it is supposed to be doing.
PostPosted: Sat Nov 04, 2006 5:37 am
TimKeith wrote:
........ Can the '92 four speed O/D transmission swap into my '89 ?
Yes.
 Post subject: Re: Ciera 3.3 V6 won
PostPosted: Sat Nov 04, 2006 9:46 pm
compression test might be a good idea after a head gasket swap.
PostPosted: Sun Nov 05, 2006 12:21 am
Interesting. The only information he gave, and it's not only useless, it diverted your attention from the actual problem.
Would that make it less than useless?
Have we seen any signs of a lack of compression? For that matter, have we seen any evidence that the starter even turns the flywheel to make that compression? Do we even know why he replaced the gasket (or the starter) in the first place?
When troubleshooting cases like this, one must always start at the beginning. What one finds there, will show the path to the solution. If one starts in the middle (compression test) of the process, and he finds low compression, is a head gasket the cause?. It it shows the right numbers, where does he go next. The internet?
He has not shown any evidence of a fubar head gasket, but he has shown a willingness to test the condition of parts, by replacing them,and he has asked how to replace parts that he removed. Leads me to believe something was not reassembled correctly. Might be as simple as forgetting to reattach a wire.
In this case, the biggest obstacle is, we may be trying to clean up a "china shop" while the "bull" is still in it.
If the car were in my shop, I would know, just by the reaction of the starter, whether to suspect a head gasket, or even the starter itself.
The starter is the second step in the process, and for good reason. Its use in this area makes it one of the more valuable diagnostic tools found in any shop.
PostPosted: Mon Nov 06, 2006 10:22 am
True, the compression test is not the first place to start, or even a good place at all. Should not have suggested it off the bat.
But reading from all the overheating that car went through, I am sure that is the reason for the head gasket replacement. I suppose even with a leak (or multiple for that matter) in the gaskets, the car would run rough, or show signs of low compression upon engaging the starter. (Yes, now I see what you mean, he had starter problems also, so no one knows if it just wont turn over).
A compression test (he did not mention if he did one) is a great tool when replacing the head gaskets, to check the condition of the motor after a disaster like that.
Norm, you are right, we need more info from Tim, not one-liner suggestions. Tim, hows that car coming along?
PostPosted: Tue Nov 07, 2006 12:08 pm
The temp sender was not working, I overheated the motor and blew a head gasket. I took the heads to a machine shop, who resurfaced them - he said the heads were okay "as is", he also pressure checked the valves. I installed the heads with new bolts, but let the car sit for six months before doing anything further. I also installed a new water pump.
The 3300 motor will crank, it gets spark. There is fuel pressure, but I don't know how much pressure as I don't have the guages. This motor always started immediately and ran fine before.
There aren't any repair shops close to me, I live in a rural area.
PostPosted: Tue Nov 07, 2006 5:02 pm
TimKeith wrote:
The temp sender was not working, I overheated the motor and blew a head gasket ........
Sender did not cause it to overheat.
TimKeith wrote:
........ I took the heads to a machine shop, who resurfaced them - he said the heads were okay "as is", ........
OK, until we know different, we'll take his word for it.
TimKeith wrote:
........ I installed the heads with new bolts ........
Did you chase the threads and oil the bolts?
TimKeith wrote:
........ but let the car sit for six months before doing anything further ........
Other than a low battery it's no problem.
TimKeith wrote:
........ I also installed a new water pump .......
Did the old pump cause the overheating?
TimKeith wrote:
........ The 3300 motor will crank, it gets spark ........
Does it crank like it did before your problems began? Will the spark jump a quarter of an inch? Does the spark occur at the right time?
TimKeith wrote:
........ There is fuel pressure, but I don't know how much pressure as I don't have the gauges ........
Do whatever it takes to get a gauge.
TimKeith wrote:
........ This motor always started immediately and ran fine before ........
So, all we have to do, is, find out what changed.
TimKeith wrote:
........ There aren't any repair shops close to me, I live in a rural area.
Don't you just love a challenge?
PostPosted: Tue Nov 07, 2006 7:12 pm
The cooling system was in poor condition. The heater core had corrosion and began to leak, that's how the car overheated. I have replaced hoses and cleaned the radiator. I installed a water temp guage, but did not use a tee to the existing sensor. Is the factory temp warning sensor necessary for the engine controller computer?
It is a beater. I've known people who got over 300,000 miles from these motors with poor maintenance. I have not had the car for long before the overheating incident. The transmission was in worse shape than the cooling system, badly sludged, it won't shift into 2nd gear until the motor has warmed for at least 2 minutes, then seems to work fine.
I know of another person who had a similar problem with a 3300, they had broken a wiring connection when they worked on the heads. The Haynes manual is not very useful for diagnosing this particular problem.
My father is very good at fixing electrical problems when he knows what to test.
A well maintained beater is a good deal, it just takes some time to get there, you have to understand details of how things work.
PostPosted: Wed Nov 08, 2006 5:51 am
TimKeith wrote:
The cooling system was in poor condition. The heater core had corrosion and began to leak, that's how the car overheated ........
And the subsequent damage was caused by the drivers lack of attention to the prior warning signs.
TimKeith wrote:
........ I have replaced hoses and cleaned the radiator ........
Should have been done before driving the car.
TimKeith wrote:
........ I installed a water temp gauge, but did not use a tee to the existing sensor ........
Waste of your time and energy. The original warning device was more than adequate.
TimKeith wrote:
........ Is the factory temp warning sensor necessary for the engine controller computer? ........
Yes. Everything in the electrical system has a purpose and, therefore, is necessary.
TimKeith wrote:
........ It is a beater. I've known people who got over 300,000 miles from these motors with poor maintenance ........
Poor maintenance? By whose standards?
Different cars. Different situations. Different circumstances. different histories. Different everything. The only thing they have in common is, that the engines share the same design and manufacturer.
All humans share the same design and manufacturer. If our expected lifespan is 80 yrs, are we to assume we will all survive to that age?
How do your examples show your car will make it to 300K?
TimKeith wrote:
........ I have not had the car for long before the overheating incident ........
Long enough to know about the faulty cooling system beforehand?.
TimKeith wrote:
........ The transmission was in worse shape than the cooling system, badly sludged, it won't shift into 2nd gear until the motor has warmed for at least 2 minutes, then seems to work fine ........
Did you know that when you acquired the car? Do you know the problem is not the filter?
TimKeith wrote:
........ I know of another person who had a similar problem with a 3300, they had broken a wiring connection when they worked on the heads ........
How does that apply to your situation? Would it make any difference if it was a 3800? Or a 455? Or a 350 Chev?
TimKeith wrote:
........ The Haynes manual is not very useful for diagnosing this particular problem ........
It is a guide for those who already have a working knowledge of the basics.
TimKeith wrote:
........ My father is very good at fixing electrical problems when he knows what to test ........
Helpful, if the problem is electrical. Have him check all the wiring, in and, around the area you worked in.
TimKeith wrote:
........ A well maintained beater is a good deal, it just takes some time to get there, you have to understand details of how things work. ........
There are many decisions to be made in the choice of a "beater". First and foremost is, whether it can easily serve that purpose, or if it will be a "money pit" that spends more time down, than running.
The initial choice is not one to be made by a novice.
TimKeith wrote:
........ you have to understand details of how things work.
As I see it, you do not have that understanding. You did learn a small bit, when you wasted cash on a relay you did not need.
Right now, you have fuel and spark, but you do not know how much, or if the spark timing is correct.
If the starter sounds/feels exactly like it is supposed to, you have compression and it will start.
Crank the engine for about 3 seconds, remove a plug and inspect it. If it's wet, you have fuel, but you don't know if it is the right amount. Check the pump with a gauge.
While the plug is out, attach it's wire and ground the thread area to a metal part of the engine. Have someone crank the engine and you will see and hear the spark across the gap. If you feel it, you didn't have it grounded. If you witnessed a spark, it's probably enough to run the engine.
Now put your finger in the plug hole, and crank the engine again. If there is compression, you will know it.
Repeat the last 3 steps on each cylinder.
Check back after you have finished all of the above.
PostPosted: Wed Nov 08, 2006 9:42 am
The Chiltons manual says to never crank this motor motor with the ignition on when any of the engine control wiring is disconnected, as this can cause damage. I probably did crank the motor with some wiring disconnected. This can damage the coil packs.
My father was a technician for a company which manufactured engine control computers for Ford, I am sure that he can fix this if he can get accurate information. He repaired the internals of the computer on his Honda when the dealer technicians did not seem to know what was specifically wrong with it.
PostPosted: Wed Nov 08, 2006 11:42 am
Let us know how it goes.
Users browsing this forum: Bing [Bot] and 16 guests
