PostPosted: Sun Nov 05, 2006 7:58 pm
We just bought a 1988 Olds Delta. It ran great for about a week. Then one day it was deader than a door nail. We took out the battery, bought a new battery, put it in, and it started right up. I drove it for a couple of days, it started while running around doing stuff. Then it sat for about 4 days, and now it is dead again. Does this sound like it now needs a alternator? Thanks, Karen
PostPosted: Sun Nov 05, 2006 8:04 pm
well...that would sound like it needs an alternator for sure. But to be really sure...you can bring it to a local auto zone, murrays...or whatever local autoparts store like those I listed...as they will test your alternator out for free.
PostPosted: Sun Nov 05, 2006 8:10 pm
Something could be draining the battery.
obviously
PostPosted: Sun Nov 05, 2006 9:15 pm
Thanks for your reply, guess we need to charge the battery and drive it over to Auto Zone to test the alternator, and I assume that if the alternator is OK, then something else is draining it, drat, hope not!
Karen
PostPosted: Mon Nov 06, 2006 12:14 am
Hi bluecar87, hello everyone,
We just bought a 1988 Olds Delta. It ran great for about a week. Then one day it was deader than a door nail ........
Odds are, that's why the previous owner sold it.
First step, in your case, would be to check the alternator belt tension, then a battery test, followed by an alternator test.
........ Does this sound like it now needs a alternator?
At this point, any speculation about the cause of your problem, will be just that, speculation.
Having said that, based on (and only on) your statements "it was deader than a doornail", and "it sat for about 4 days, and now it is dead again.", your problem was not the battery, and is not the alternator or drive belt.
If the tests show both to be OK, I will have one question, and we can continue from there.
PostPosted: Fri Nov 10, 2006 1:51 am
Update
We had the car worked on. Found out our new battery from Auto Zone had a bad cell. So we were able to bring the battery back for a refund and we had another new one installed at the Chevy dealer. So far it is starting after we turn it off, but it has only been two days, if it still starts after a week, we'll know for sure it was the new battery that was the problem and everything is ok now.
Karen
PostPosted: Fri Nov 10, 2006 2:26 am
bluecar87 wrote:
Update
Karen
good to hear it went good for you. hope you the best.
PostPosted: Fri Nov 10, 2006 2:36 am
Good news. Thanks for the update.
PostPosted: Tue Nov 14, 2006 12:37 am
OK, this is getting redundant! Here's a recap. Bought a 87 olds Delta 88, 92000 miles, Drove car, three days later, then dead car, not even interior lights, so, new battery, runs good, then dead again and no lights at all. Car dealer said the "new" battery had a dead cell, so another new battery. Car runs good for a few days again, but, only short trips, like 2 miles to the store and it didn't run more than 15 minutes. Now this is strange. I went out this morning, it was cold, I started the car, it turned right over. I went back in and let it warm up for about 15 minutes, I went out, got in the car, and it just quit, and was deader than a door nail, AGAIN! What do you think? I am going to take it back to the dealer that said it was the battery, now I don't think that is the problem.
KarenB
PostPosted: Tue Nov 14, 2006 1:27 am
So you had it running for 15 minutes, got in the car...and it stopped running? Does the starter crank the engine at all? Does it start after it has cooled down again? No lights at all again?
Sounds like alternator to me if it won't crank and no lights after running it for 15 minutes. Did they test it? Are all the wires connected to the alternator (connector that plugs into alt and positive wire that goes from alt to battery)?
PostPosted: Tue Nov 14, 2006 2:15 am
The car is now very dead, no interior lights, nothing, no cranking, it's like someone disconnected the battery. The dealer told us the first time that he couldn't test the alternator because there was something wrong with the battery and it wouldn't register right, something like that. It didn't make sense to my husband, but you know, we believe everything the mechanic tells us. I guess our next step is to jump it and drive it over the mechanic (the dealer where we bought it) and get the alternator tested.
KarenB
PostPosted: Tue Nov 14, 2006 10:52 am
The no interior lights, right after a successful start indicates to me that the battery terminals may not be in the best condition. A battery will not go completely flat 15 minutes after a successful start.
PostPosted: Tue Nov 14, 2006 11:32 am
bluecar87 wrote:
........ got in the car, and it just quit, and was deader than a door nail ........
Not consistent with a normal battery or alternator problem. If there was enough amperage in the battery to start the car normally, 15 minutes of running, without the alternator, would not drain everything out of the battery, even if all accessories were in operation.
So we are working with the same definition of "deader that a doornail". If you open the door, is the interior light (however dim it might be) on at all?
Did it die before, after, or when you put it in gear?
........ The dealer told us the first time that he couldn't test the alternator because there was something wrong with the battery ........ ........ It didn't make sense to my husband ........
Doesn't make sense to me either, but I'm also not comfortable second guessing a mechanic through a third party.
........ our next step is to jump it and drive it over the mechanic (the dealer where we bought it) and get the alternator tested.
If you can boost it, then drive it there, the alternator is working, and the problem is intermittent. In this case, Brando's loose connection is looking very likely.
Get it tested anyway, along with the battery.
Although extremely unlikely, it is possible for the alternator's regulator to send too much voltage to the battery, causing a short circuit in a cell. If that is proven to be the case, you will need to buy both.
If they check OK, next is a test for excessive current draw at the battery.
PostPosted: Tue Nov 14, 2006 12:46 pm
88delta88 wrote:
........ the battery terminals may not be in the best condition ........
Good call.
In this case the interior lights should have been dim, not out completely. It is worth rechecking anyway.
Loose/dirty cables can keep the starter from working, but power for a running engine comes from the alternator. If it died when she put in in gear, the combination of the the RPM drop, a faulty cable connection, and a loose belt, could very well be the cause. That is, assuming 15 minutes of running was enough to contaminate a loose connection.
Still the cables are the first (after the belt) to be checked after one of these incidents. They should have been cleaned, along with the belt check, as part of both battery tests and both battery installations.
Doesn't mean they were.
PostPosted: Tue Nov 21, 2006 2:48 am
Well, you guys are good! Cross your fingers, but they found out it was the battery cable, you were right. I have had it back for a week, drove it, let it sit, let it run for 20 minutes, turned it off, started it again, it's still going good.
Thanks for your help, hope this problem is fixed! Karen
Users browsing this forum: Bing [Bot] and 16 guests
