 Post subject: Plastic Welding
PostPosted: Sat Nov 11, 2006 3:13 pm
While I was removing my door panel one day (the window switch panel needs to be removed before doing so) a clip that holds the window switch panel in place broke.
I contacted the dealer to see if they could get a replacement...no dice. I tried super gluing the clip back on....that only made me have to take the door panel off again in order to get the clip that broke off in seconds.
So, what to do? Well, I stopped at NAPA to see what kind of plastic adhesives they had...knowing that my piece was ABS, it says it right on the back of the panel.
I ended up getting this:
765-2420 Plastic Welding System, it says specifically that it will work with ABS. It specifically says that it will not work on polyethylene or polypropylene plastics...so it pays to know what you're working with. This "system" was under $4 for me....with discount.
Funny, it says "Say NO to DRUGS" on the back...this stuff is definately strong, don't want to inhale it much. Contains Methyl Methacrylate and Methacrylic Acid. It actually fuses the plastic together, no electric plastic welder necessary.
In conclusion, this stuff works great! Waited an hour for it to fully cure, and installed the window switch trim panel....the clip didn't break and it seems to fit tighter than it did before. :thumbup:
 Post subject: Re: Plastic Welding
PostPosted: Sat Nov 11, 2006 3:28 pm
I hate those door panel switches. At least the door panels are super easy to remove. Although I've had min off so much, the cardboard is getting worn out where the clips go :confused:
PostPosted: Sat Nov 11, 2006 3:43 pm
Forgot to say this is on my intrigue...not the delta. Yes, the door panels are even easier to remove on the intrigue, no cardboard--just plastic...that was the dumbest idea ever.
PostPosted: Sat Nov 11, 2006 5:29 pm
good stuff man
Users browsing this forum: Bing [Bot] and 16 guests
