 Page 1 of 1 [ 8 posts ]
PostPosted: Mon Nov 13, 2006 7:44 am
Hey all, new here. Funny how my first post is a problem. I've been reading the site for a while as I got very into forums while owning a mercury cougar which was taken out by a drugged up grandpa.....That's why I know own a 1995 olds 88...luxury...anywhoo
My car died last night while driving and I'm a pizza delivery guy. I've only had the olds for about 500-600 miles and I've treated her nice.
So after my first stop last night I have to make a right hand turn into traffic and this traffic just wouldn't break. It just kept coming. I finally come to terms with taking off and stomping the gas. So I do. As I was watching the mph come up I noticed it seemed a bit sluggish at first, then started coming up like it should. About that time I noticed the RPM guage was damn near the redline out of the corner of my eye. I let off the gas, the rpms shot down indicating a gear shift. I hit the gas again, this time not flooring it. nothing, I let off and did it again and still nothing, so I floor it again and it sort of goes but not really, I have a red light coming up so I let off and it really just sort of shits itself and guage lights start coming on and I realize, my engine is off.
I was able to use my momentem and strength to pull this as of now, no power steering boat off the road and into an all but abandoned parking lot.
I shift back to park and try to restart it and it turned and turned and turned but never came to life.
Several hours later I returned to the vehicle. It still turns over fine and sounds no different turning over than it ever did. It just doesn't start.
The only other problem I've had with the car is a slow but steady coolant leak that I can't find. But the temp was right at 195-200 when this happened.
I'm thinking fuel pump although it's odd I had no symptoms before this and I can still hear that whir sound when I put the key to the on/run position. However, this would not be unlike what happened to my LeBaron.
If anybody has any ideas on what I should check and/or what they think the problem may be, lemme know. I'll really appreciate it as I don't want to have to take it to a shop.
Thanks,
preclose
I was actually planning to make my grand intro to the olds connection tomorrow on my day off. I was gonna wax her up real nice and get some photos and the bitch treats me like this, dead, and sitting in my front lawn since the tow guy couldn't make the turn that's hard enough when it's not on a tow truck.
PostPosted: Sat Oct 13, 2007 2:22 pm
A 3800 is a good engine, had it in my 92 Silhouette. Same thing happened to me, was the electronic module. Had to tow it to the dealer, cost me $300 to get it fixed, then I traided it in and only got $1500 for it. Anyway, make sure you are getting gas to the injectors. Also, might be a ground on the fuel pump. Had the same problem on my 88 Firebird. After replacing the fuel pump, car sat in garage for 2-years. started each week fine. When I drove it to work, it would just die, and not restart. Had to bang on the gas tank with a hammer to get it to start. Sold the beast 2-months ago. Bought a 1971 Olds 442. Love it. Good luck with your Delta 88.
1999 Alero
2002 Bravada
PostPosted: Sat Oct 13, 2007 2:33 pm
symptoms sound like an intake gasket finally let go, especially with the misshifting (lack of vacuum for modulator) & the coolant leak. anyone else? how to test?
PostPosted: Sat Oct 13, 2007 4:14 pm
First thing to do is pull the oil dipstick. If the oil is milky, you know your problem lies in a failed gasket. You can test for a coolant leak by using a cooling system pressure tester. If the oil isn't milky, I would do the following.
I would start simple- fuel and spark. Make sure you have the basics before you dive into it further.
Test the fuel pressure via the test port in the fuel rail. You should be able to rent the gauge, or they are relatively inexpensive.
Test for spark with a spark tester. Remove a couple plugs and note the condition, if you are getting fuel, they should be wet with fuel. These two tests shouldn't take much longer than 15-20 minutes.
If it passes these tests, report back with your findings, and we will be able to narrow it down further from there.
It could be lots of things, but the idea here is to minimize cost by buying the right parts, if required, and finding the root of the problem so it doesn't happen again-
PostPosted: Sun Oct 14, 2007 3:56 am
Posted: Mon Nov 13, 2006 8:44 am ........
Eleven months, to the day. It's probably either fixed, or scrapped, by now.
88delta88 wrote:
........ especially with the mis shifting ........
Not the way I saw it.
preclose wrote:
........ the RPM guage was damn near the redline ........ ........ I let off the gas, the rpms shot down indicating a gear shift ........
Isn't that the way it's supposed to happen?
First thing to do is pull the oil dipstick ........
First, check for fuel in the tank.
........ If the oil is milky, you know your problem lies in a failed gasket ........
His leak was not part of the problem.
preclose wrote:
........ It still turns over fine and sounds no different turning over than it ever did. It just doesn't start ........
Doesn't sound like a lack of compression, or the presence of liquid, in one or two cylinders.
Too much information is often worse than not enough.
PostPosted: Sun Oct 14, 2007 9:49 am
Heck- I didn't even read the OP date...
I agree-
PostPosted: Sun Oct 14, 2007 3:49 pm
hahaha! I am surprised I didnt notice that... Even more surprised no one replied to him when he first posted!
PostPosted: Tue Oct 16, 2007 5:43 am
preclose wrote:
........ I got very into forums while owning a mercury cougar which was taken out by a drugged up grandpa ........
That's as far as I got.
