It is currently Thu Nov 26, 2026 8:20 am
 Page 1 of 2 [ 22 posts ]  Go to page 1, 2  Next
 Post subject: annunciator lightt
PostPosted: Thu Dec 21, 2006 11:37 am
My fasten seat belt light stays on all the time. I have an 83 Cutlass Supreme, does anyone know how I can fix this?
Thanks in advance
 Post subject: Re: annunciator lightt
PostPosted: Thu Dec 21, 2006 11:45 am
Pull the bulb. :lol: I know it sounds like a smartass response, but it could be numerous wiring faults that could be a pain to fix. It's not like you need a seatbelt light.
PostPosted: Thu Dec 21, 2006 12:56 pm
thanks for your response. But I think getting at that bulb to pull it will be a pain in the ass of it's own.
PostPosted: Thu Dec 21, 2006 6:38 pm
Images: 1
Why don't you disconnect the seatbelt warning connector from the seatbelt clasp... the wire should be under the drivers seat. That might work right?
PostPosted: Thu Dec 21, 2006 7:22 pm
Nope, mines been disconnected for months and it still shows up for a couple seconds.
PostPosted: Thu Dec 21, 2006 7:34 pm
Images: 1
But is yours the problem?
sean000 wrote:
My fasten seat belt light stays on all the time. I have an 83 Cutlass Supreme, does anyone know how to fix this?
Thanks in advance
If disconnecting doesn't work try putting a piece of black electrical tape over the seatbelt light.
Does the light turn off when you push the clasp button?
PostPosted: Thu Dec 21, 2006 11:59 pm
Hi sean000, All,
Welcome to TOC
......... does anyone know how I can fix this?
The switches are in your seat belt retractors, and are, in most cases, the cause of that problem.
The upper right portion, that pertains to seat belts, shown in this link is very similar to yours, and may be of help.
If you plan on keeping the car, and doing your own work, I suggest buying a Factory Service Manual like this one. I've found the wiring diagrams, in these manuals, to be an invaluable diagnostic aid.
PostPosted: Fri Dec 22, 2006 12:00 am
If the belt light still comes on when the plug is disconnected, try shorting the two pins together. There are only two states to a seat belt system, connected or disconected. This will prove if the belt buckle is broken, or there is a malfunction elsewhere.
PostPosted: Fri Dec 22, 2006 12:44 am
87Delta wrote:
Pull the bulb .........
Erroneous Restrictionism! wrote:
Why don't you disconnect the seatbelt warning connector from the seatbelt clasp ........
........ try putting a piece of black electrical tape over the seatbelt light ........
Your comedic efforts are more suited to the off topic section.
Or, is there another definition of "fix" that I do not know about?
PostPosted: Fri Dec 22, 2006 12:58 am
There are also sensors in the seats that close the same circuits when weight is placed on them. If one fails to open, when unloaded, and the belt for that seat is not extended enough to open its switch, the light will stay on.
PostPosted: Fri Dec 22, 2006 12:19 pm
Images: 1
They had the technology in 1983 to do that?..Never knew that!
Why not start with the cheapest "fix"? If the seatbelt still funtions normally then why not "pull the blub" or "disconnecting the wires". The only thing that I could see changing is the "seatbelt light" will be off. If worried about a possible short use common sense and bring it to an automotive electrician.
Comedic efforts? ... Your info is useful I'll give you that. However this is a discussion board and the replys were in fact still related to the topic.
PostPosted: Fri Dec 22, 2006 1:57 pm
Dont know about seat sensors... probably been around longer than most think, but I digress.
The way I see it, if you are going to fix it, fix it. Why put the effort into rigging it so the light doesnt come on when you could spend the same time and effort making it right?
If its worth doing, its worth doing right, but that of course, is just my opinion.
PostPosted: Fri Dec 22, 2006 4:10 pm
My 1973 had something similar; a switch in the seat that made the seatbelt buzzer come on if the belt is not fastened for that seat and someone's butt is there. It was on the front passenger seat only. This was removed when I had the front bench re-upholstered.
PostPosted: Fri Dec 22, 2006 4:28 pm
73Delta88 wrote:
........ My 1973 had something similar ........
That would be why my link was to your wiring diagram.
PostPosted: Fri Dec 22, 2006 5:27 pm
........ They had the technology in 1983 to do that?..Never knew that! ........
It is obvious from the content of your posts, that here is a lot you do not know. It is just as obvious that you want everyone to know how little that is.
........ Why not start with the cheapest "fix"? ........
He asked for a fix. You did not suggest one,
You have no idea how to address his problem, so you told him to put electrical tape over the light.
How very helpful you are.
........ If the seatbelt still funtions normally then why not "pull the blub" or "disconnecting the wires" ........
Because it will not "fix" the malfunction.
........ The only thing that I could see changing is the "seatbelt light" will be off ........
The operative phrase here is: "that I could see". Comes under the same heading as: "Never knew that!".
........ If worried about a possible short use common sense and bring it to an automotive electrician ........
Nothing to do with his request. He chose to come to TOC, not to go to a shop.
........ Comedic efforts? ........
Yes.
........ Your info is useful I'll give you that ........
Of course it is. If it was not, I would not have posted it.
........ However this is a discussion board ........
Yes, it is.
........ and the replys were in fact still related to the topic.
The ones that have actually contributed to the solution of his problem, yes.
Yours? No.
Did you know you misspelled "function" and "replies"?
Users browsing this forum: Bing [Bot] and 15 guests
