Ian Szgatti wrote:
I'm pretty sure you'd want to see around 11 to 14 ohms... I don't know how your getting 20+, but I can say that if you hit up a "u pick it" scrap yard with a multi-meter, you can pick up all six. Sometimes though you'll get an injector that won't show resistance problems until its hot, in which case you should get a few more for good measure.
You can also have the 'picked' injectors tested. A good shop should have the proper equipment. They can anaylize the spray pattern, clean the injector, and get it hot to see if there are issues after warm up.
I don't know what the machine is called, but when I took Auto Tech at the local comm college, they had this machine.
