It is currently Thu Nov 26, 2026 8:40 am
 Post subject: Starting problems
PostPosted: Fri Dec 29, 2006 8:42 pm
Can someone help me? I have an 83 Cutlass Supreme 3.8L V6, and it's having problems staying running on cold days when the engine is cold. When I start it in the morning it runs fine for a few seconds and then stalls. If I anticipate the stall and tap the gas a little I can keep it going and then it stays running on it's own fine. Also, if I don't give it a really good warm up, when I put it into drive or reverse it will stall also. Any ideas what this could be?
Thanks in advance
 Post subject: Re: Starting problems
PostPosted: Fri Dec 29, 2006 9:20 pm
Thanks in advance
First off, welcome to TOC!
I think we can help.
IIRC, that engine is carburated, and if so, it will have a choke. It sounds to me like the choke is malfunctioning. I am not sure what type of choke or carb you have, but I think a simple choke adjustment should have you on your way.
Its also possible that it is an electric choke, and that it isnt getting power, in which case its a whole other can of worms.
In my experience a service manual for your car is an invaluble tool in maintaining your car. With it, and the site, you can conquer anything you mechanic aptitude will let you!
Hope this helps,
PostPosted: Fri Dec 29, 2006 10:37 pm
........ a simple choke adjustment should have you on your way ........
Yup.
........ Its also possible that it is an electric choke ........
More than possible.
........ and that it isn't getting power ........
If he gives it a really good warm up, the problem goes away. Your first answer was the right one.
........ In my experience a service manual for your car is an invaluable tool in maintaining your car ........
Yes, hard to find a more useful tool. You can check one out here.
PostPosted: Sat Dec 30, 2006 8:01 pm
Well I gave the carburetor and all linkages a good cleaning, and tightened the mounting bolts (seemed surprisingly loose) the other day, and I think the problem is solved. The last two days, she hasn't wanted to stall after the start. Thanks for all your helpful posts guys!
Happy New Year!
Sean
PostPosted: Sat Dec 30, 2006 8:23 pm
sean000 wrote:
........ and tightened the mounting bolts (seemed surprisingly loose) ........
Seems, you had a vacuum leak at the base of the carb, and your choke was/is adjusted properly.
If/when it happens again, it will need a new gasket.
