 Page 1 of 1 [ 8 posts ]
 Post subject: Door sags
PostPosted: Sat Dec 30, 2006 10:10 pm
My Olds has fallen victim to the sagging door sickness that plagues so many old cars. The drivers door sags and is now damaging the black stricker on the door frame (that black or gray bolt like thing that the latch grabs onto when you close the door) and is now pulling it slowly out of the door frame. If I push up on the bottom of the door I can move the end closest to the back up about 1.5 inches. Is this an issue that could be repaired with new pins? Should I take the car to a body shop? Please let me know what other information is needed!
 Post subject: Re: Door sags
PostPosted: Sat Dec 30, 2006 10:56 pm
Seems the bushings in the door pins are shot. The hinges may be worn too, but its impossible to know without taking the door off. Worst case senario, you will need to find some hinges in a junkyard, or ebay, and then install the new pins and bushings. You may want to consult a body shop when it comes to lining the door back up.
I once did this on my truck, and I just took the measurements from the fender to the hinge, and when I installed the 'new' one, I put it at that mark. One could also trace the hinge with a Sharpie or paint pen to achieve the same result. But you may need some fine tuning when all is said and done. Also, if you have any door electrics, be wary of them as not to pull the wires too much. Find the connector if you can, and disconnect them.
Depending on your abilites, you should be able to knock it out in an afternoon.
Regards,
PostPosted: Sat Dec 30, 2006 10:59 pm
Any ideas what a body shop might charge to do the whole thing, Im not trusting in my abilites to do this myself.
PostPosted: Sat Dec 30, 2006 11:03 pm
Not sure... Don't have much experience with body shops. Most shops dont like it, but it will probably benefit you to but at least the 'new' hinges so you dont have markup on a junkyard part. But thats up to you.
I would call around to a few, or get a couple estimates done at least.
PostPosted: Sat Dec 30, 2006 11:23 pm
........ Is this an issue that could be repaired with new pins? ........
Yes. More accurately, hinge repair kits.
........ Should I take the car to a body shop?
Yes, they can better assess your situation in person, than we can remotely. They can tell you what will be involved and quote a price for the job.
Then, if you choose, we can talk about your options.
PostPosted: Sun Dec 31, 2006 2:48 am
Im going to try and visit some body shops Tuesday to get the ball rolling on this. Thanks for the input.
PostPosted: Sun Dec 31, 2006 3:25 am
I didn't think about it until now. '85 FSM should cover R&R of the doors and hinges. Mine do, but my latest is '64.
PostPosted: Mon Mar 09, 2009 11:25 pm
Update to a very old post, but I figure if someone searches "door hinge" here, this comes up at the top, so I might as well post the conclusion here.
Finally I got off my butt and brought the Olds to a body shop to replace the pins in the driver side door. The cost of labor/parts was $167.90. They guy explained the whole thing, and I'm sure those more mechanically inclined then I could do this on their own. I'm all thumbs.
