It is currently Thu Nov 26, 2026 10:00 am
 Posted: Sun Dec 31, 2006 4:23 am |
GraveReaper0 wrote: ........ Whatever makes the mph needle move is making the sound, and whenever it does, the needle jumps just a bit. It doesn't stop until the car stops ........ Not enough information to say whether it's the cable or the head. GraveReaper0 wrote: ........ there's probably only one light working on it ........ Light bulbs are easy to change. You do not have a FSM yet? GraveReaper0 wrote: ........ So it there someone out there that can fix gauge clusters for supremes? ........ Yours is no different than any other mechanical speedo. Any competent auto repair shop can handle it. GraveReaper0 wrote: ........ Or can I possible buy one?
If you plan to do the work yourself, try GM first, followed by your local Junque Yarde and eBay.
If not, it is best to let the shop get the parts.
Erroneous Restrictionism!
 Posted: Sun Dec 31, 2006 11:45 am |
88 Coupe wrote: ................ Junque Yarde....................
What is that?...Do you speak french Norm?
 Posted: Sun Dec 31, 2006 6:29 pm |
Erroneous Restrictionism! wrote: ........ What is that? ........ Humor. Erroneous Restrictionism! wrote: ........ Do you speak french ........ ?
Is it French?
Is it any of your business?
Is it related to the topic?
 Posted: Mon Jan 01, 2007 1:16 am |
88 Coupe wrote: Is it French? Not sure if its french...depends on how you think, if it's french 88 Coupe wrote: Is it any of your business? Could be, I may be french if thats french to you, what do you think I'm thinking? 88 Coupe wrote: Is it related to the topic?
If it's an attempt to say "Junk Yard" in french!
 Posted: Mon Jan 01, 2007 1:26 am |
 Posted: Mon Jan 01, 2007 1:35 am |
Erroneous Restrictionism! wrote: Not sure if ........ Read what is there, not what you think might be there. Erroneous Restrictionism! wrote: ........ Could be ........ It is not. Erroneous Restrictionism! wrote: ........ If it's an attempt
Yes, it is off topic.
 Posted: Mon Jan 01, 2007 2:08 am |
88 Coupe wrote: Erroneous Restrictionism! wrote: Not sure if ........ Read what is there, not what you think might be there. Erroneous Restrictionism! wrote: ........ Could be ........ It is not. Erroneous Restrictionism! wrote: ........ If it's an attempt Yes, it is off topic.
You can't answer the whole question in front of you can you?....."La chat a recu votre langue"?...Faites je pense votre muet?....Ne moi insultez pas!
Est cela comment vous dites le yard de bazar?
 Posted: Mon Jan 01, 2007 2:52 am |
Erroneous Restrictionism! wrote: ........ You can't answer the whole question in front of you can you? ..........
The answer is there. All you have to do is read it.
Or is it, that you cannot read my posts because you do not speak or read English well enough to comprehend them?
You cannot comprehend them, not because of Dyslexia, but because I do not write in French.
If I did write in French, I would not have used that play on words, because the humor only works in English.
You have been hijacking this, and other, threads because you have no idea what you have been talking about.
 Posted: Mon Jan 01, 2007 3:26 am |
88 Coupe wrote: You have been hijacking this, and other, threads because you have no idea what you have been talking about.
You are full of shit my friend.. Get off your high horse, come down where the air is not too thin!
What's it with some Americans with "highjacking" anyways?
Yes I'll overreact and yes I'll read what I see...Your displays of arrogance create my retaliations.
Prove me wrong...
 Posted: Mon Jan 01, 2007 4:17 am |
 Posted: Mon Jan 01, 2007 12:18 pm |
Erroneous Restrictionism! wrote: 88 Coupe wrote: You have been hijacking this, and other, threads because you have no idea what you have been talking about. You are full of shit my friend.. Get off your high horse, come down where the air is not too thin! What's it with some Americans with "highjacking" anyways? Yes I'll overreact and yes I'll read what I see...Your displays of arrogance create my retaliations. Prove me wrong...
With this American, hijacking means keeping the damned thread on topic. Your questioning Norm on whether or not he speaks fluent French is better suited to a PM, a new thread, or not typed at all. Speaking French has absoultly nothing to do with repairing GraveReaper0's cluster.
Many good, informational threads are ruined with this crap.
So now do you get what 'it' is with 'hijacking'? I'm positive it has nothing to do with race, nationality, or creed, but you seem to think so.
I think you might be on glue.
Back to the topic...
Did you find or try a fix yet?
 Posted: Tue Jan 02, 2007 12:25 am |
GraveReaper0 wrote: ........ I've found plenty over at car-part.com
One thing to keep in mind when dealing with Ye Olde Junqe Yarde.
The car that donates the part, is the same age, and probably has the same high mileage, as yours.
In this case, you should be OK, and you can learn a lot by doing it yourself.
GraveReaper0
 Posted: Tue Jan 02, 2007 5:35 pm |
It souldnt be hard. When me and my friend were replacing the dash in my Ciera, there were a couple screws holding it and some wiring, no problem, hopefully this car will be the same.
And could I swap it for a different one? I like the cluster the hurst has.
http://cgi.ebay.com/ebaymotors/Olds-442 ... dZViewItem
But is the hookup different? And would the oil, voltage, and other gauges work since I don't have them right now?
