It is currently Thu Nov 26, 2026 9:48 am
 Page 1 of 1 [ 10 posts ]
 Post subject: Heater core...83 Cutlass
PostPosted: Wed Jan 03, 2007 7:37 pm
Well I think my heater core just crapped out on me. Nice residue all over the windows along with a funky smell. I priced out a new core...about $50cdn, and am planning on installing it this weekend. Has anyone done the job before that could tell me how big of job it is. Talking to a few friends it sounds a little time consuming.
Thanks,
Sean
PostPosted: Wed Jan 03, 2007 8:00 pm
Thanks,
Sean
IIRC, you need to remove the "plate" from the top of the heater box, and then the core should almost pull out. There might be a retention strap or something holding it down, but the majority of the work is taking the heater box access plate off. Its about a dozen screws IIRC. Its been awhile since I did one, but i knocked it out in about an hour and a half.
It might take longer, depending on your skills, and depending on what else you decide to do to the car while you are working on it.
PostPosted: Wed Jan 03, 2007 8:05 pm
Is the heater core what blows the air? Or is there something else for that. My heat doesn't work at all, because there is no air moving. :(
PostPosted: Wed Jan 03, 2007 8:09 pm
That's probably the Blower Motor itself then.
Thanks Andrewk..bout an hour and a half eh. Did you have to drain all your coolant first or can you clamp off the hoses some how?
PostPosted: Wed Jan 03, 2007 8:19 pm
The heater core is like a small radiator. Coolant flows through it, and the blower motor blows air through it, which is what gives you hot air at the dash.
PostPosted: Wed Jan 03, 2007 9:31 pm
It could be a number of things, the blower motor to just fail suddenly is unlikely. Of course it is possible. Would more likely to be the blower motor resistor, relay, or switch.
Here's the R+R instructions for your heater core:
Heater Core: Service and Repair wrote:
1. Disconnect battery ground cable and drain cooling system.
2. Disconnect heater hoses.
3. Disconnect electrical connectors from heater module.
4. Remove module front cover screws.
5. Remove heater core from module.
6. Reverse procedure to install.With A/C
2. Disconnect heater hoses from core.
3. Remove retention bracket and ground strap.
4. Remove module rubber seal and screen.
5. Remove right hand windshield wiper arm.
6. Remove attaching screws from the diagnostic connector, hi-blower relay and thermostatic switch.
7. Disconnect all electrical connectors from top of module.
8. Remove top cover from module.
9. Remove heater core from module.
10. Reverse procedure to install.
PostPosted: Wed Jan 03, 2007 10:45 pm
The heater core is plumbed in from the back of the intake and from the water pump. You shouldnt lose much coolant, only whats in the core if you are careful. Remember that the rear of the intake is the lowest point on top of the engine, so you will want to hold that hose up so you dont start dumping coolant everywhere.
You can clamp off the hoses with a tool made for that purpose.
If you havent done it for awhile, a good coolant drain and flush cant hurt anything.
PostPosted: Sun Jan 07, 2007 2:50 pm
Well, I installed the heater core and flushed the coolant system this weekend. I think they're might be an air pocket in the lines because I only added about 7 Liters of Coolant and the Rad is full. Also, the return line from the heater core doesnt seem to be getting that warm I am wondering if the coolant flowing through like it should. I am getting heat but not that much when the engine is idling. Any ideas? Maybe just need to drive it around longer to get the system going?
PostPosted: Sun Jan 07, 2007 3:30 pm
7 liters is almost 2 (~1.85) gallons. Are you checking on it after running the car long enough for the thermostat to open and let the coolant through the system? You may or may not have to add additional coolant/anti-freeze.
One symptom of air in the system is over-heating. Are you experiencing this?
If you want to, you can go ahead and "burp" the system if you feel it is a problem, won't hurt anything really. Take off the radiator cap and have the engine running for a bit. Keep an eye on the temperature. Add coolant/anti-freeze as needed.
How long are you letting the car run (idle)? It takes a little bit to warm the car up for the heat to get hot. All based on that the cooling system is functioning properly.
PostPosted: Wed Jan 10, 2007 4:50 pm
She's all good...just had to drive'er around a little more for the thermostat to open up. It's been around -20 degrees Celsius here lately.
Users browsing this forum: Bing [Bot] and 52 guests
