adma449 wrote:
........ I disconnected a wire from the distributor making it impossible for the car to fire ........
What was your purpose in doing so? Which wire did you disconnect, and why did you choose that particular one?
adma449 wrote:
........ But, this also caused the ignition to remain on after the key was turned off .........
How do you know the ignition stayed on? By key, did you mean switch? Did you disconnect the wire while the engine was running?
adma449 wrote:
........ The only way to stop the engine from turning over was to reconnect the wire and turn the key, and the motor would fire ........
Was it "turning over" or was it "running"? The starter "turns" or "cranks" it, until it "starts" to "run" by itself.
What position was the switch when you reconnected the wire? What position did you place it in, to stop the engine?
By "would fire", do you mean, "start" and/or "run"? If so, you are saying, it ran after you shut it off.
adma449 wrote:
........ I went out to start to car ........ I reconnected the wire and turned the ignition to start the car, and it only rolled and would not fire ........
Rolled?
Fire = Start? Run?
I am guessing: It cranked, but did not start?
adma449 wrote:
........ Figuring that I had not put the wire on correctly, I pulled it off and put it on, which still did not effect the car .........
Using a VOM or test light, check to see if that connection has power. With the gear shifter in "N" or "P", move the ignition switch to the "off", "on", "acc", then in the "start" position.
When I know which wire you are talking about, I will be able to tell you what these readings should be.
adma449 wrote:
........ I ended up having to disconnect the battery from the car to stop it from turning over ........
From turning/cranking, or from running?
adma449 wrote:
........ The ignition is off, and still if you connect the battery it will turn over ........
If it turns (cranks) the engine, just by connecting the battery? That would be a problem with the solenoid relay. If it starts and runs, it will be harder to diagnose.
adma449 wrote:
........ but not fire........
It should not fire (start) with the switch in the off position.
Using a VOM or test light check the small wire that activates the solenoid relay. With the gear shifter in "N" or "P", move the ignition switch to the "off", "on", "acc", then in the "start" position.
You should only see current flow, when it is in the "start" position.
There is a "two wire" connector plugged into your alternator. Is it like this: _ _ or like this: I I ?
Post back when you have the answers.
