It is currently Thu Nov 26, 2026 9:22 am
PostPosted: Sun Jan 07, 2007 11:30 am
Hi,
I am getting a Code 54 and 55 on my olds 88 royale LS with 3800.
Can someone expand on what the codes mean - the chilton manual is vague
Thanx
The G-Man
1991 Dodge Shadow - 4 cyl.
1984 GMC 1500 straight 6.
etc. etc.
PostPosted: Sun Jan 07, 2007 3:24 pm
EGR solenoid valves get battery power when the ignition is turned "ON" and become energized when the control module completes the circuit to
ground. When a solenoid is energized, the armature, with attached shaft and swivel pintle, is lifted and the orifice is opened, allowing exhaust gas into
the intake manifold. Three solenoid valves control exhaust gas flow to produce seven combinations of EGR flow. The control module should only open
the valves when the engine is at operating temperature, above idle speed and a vehicle speed sensor signal is present.
Codes 53, 54, and 55 are EGR flow test failures. The PCM tests the medium and large EGR solenoid valves by cycling each of them "ON" momentarily
while monitoring engine speed. When a solenoid is turned "ON", the PCM expects to see a drop in engine rpm. Code 53 is set if the expected rpm drop
is not seen 8 of 12 times when the #1 solenoid is tested. Code 54 is set if the expected rpm drop is not seen 6 of 8 times when the #2 solenoid is tested.
Code 55 is set if the #3 solenoid fails 3 of 5 tests.
The PCM will run the EGR flow tests when the following conditions exist.
^ Coolant temperature greater than 84°C (183°F)
^ Vehicle in "coast down" condition (but not in fuel cut-off mode).
^ Oxygen sensor signal voltage greater than 0.566 volt.
^ Vehicle in 1st or 2nd gear.
^ Vehicle speed greater than 25 mph.
^ Engine speed between 800 - 1,000 rpm (solenoid #1 check.)
^ Engine speed between 825 - 1,025 rpm (solenoid #2 check.)
^ Engine speed between 850 - 1,050 rpm (solenoid #3 check.)
Diagnostic Diagram
Circuit Diagram
PostPosted: Sun Jan 07, 2007 6:51 pm
Beautiful - Thank You very much!
Gary
The G-Man
etc. etc.
