It is currently Thu Nov 26, 2026 10:42 am
d114125
 Posted: Tue Jan 09, 2007 5:36 pm |
Joined: Tue Jan 09, 2007 4:52 pm Posts: 4 Location: united kingdom
Hi newbie from over the pond, need help, have olds silhouette 93, v6 3.8. have just completed round trip of 1400 miles to spain and back, after driving for approx 1hr in overdrive (it is auto) car tends to sneeze when applying throttle above 70mph, seems like erratic misfire, will not clear unless you ease back on throttle, after travelling for approx 8 hrs 400miles, car decided to get worse , misfiring between 30mph and up to 80mph, coaxed car further 80miles to destination. made it phew !! following day car seemed fine ,drove car all week only very slight miss under heavy load, so started return journey, after driving 1hr car started to misfire speed approx 70mph, in overdrive, so decided to change down into drive, no problems went like rocket for 9hrs, revs reading 3000rpm, after approx 450miles car started to misfire again ,but made it to ferry, parked car for 30 hrs, when returning to car started straighted away drove at 80mph for 2hrs 30 mins in drive no problem. all suggestions would be a great help .david  ps have removed and checked fuel filter
 Posted: Wed Jan 10, 2007 8:37 pm |
When was the last time the plugs and wires were done?
Sounds very similar to a problem I had. It misfired and sometimes even backfired when warm, and when I put my foot into it. I would have never guessed the 2 month old wires were faulty, but I saw a blue arc of electricity jump from a defect on one wire end, to a defect on the wire end right next to it. Grabbed two of the old wires I had saved, replaced them, and it ran like a top.
If its due for a tune up, complete the tune up and check back.
Erroneous Restrictionism!
 Posted: Thu Jan 11, 2007 9:15 am |
88delta88 wrote: When was the last time the plugs and wires were done?
But it could be something else..that just happened to be "similar" to your problem!
It could be the Ignition Module!
It could be a timing issue!(CAM sensor)
It could be fuel issues!(Fuel injection system)
It could be MAF issues!
It could be TPS issues!
It could be a vacuum leak!
It could have been more than usual water condensation in the gas lines!....who knows!
It could be ANYTHING!
It's a fourteen year old motor!
Do you see my point?
Now this guy is gonna go off and get new wires and plugs, if the problem isn't fixed he just wasted money and has to start all over.
Hi d114125!...... Bring it to a reputable technician.
Were you using your AC during this drive?
Were these vans with these engines sold in Europe? I would like to think elevation was a factor in this, but I'm probably wrong!
The problem happened more while vehicle was in Overdrive?..Maybe transmission issues?....Speed Sensor?....TCC?...Did you use Cruise Control at all during this trip?
 Posted: Thu Jan 11, 2007 9:58 am |
Erroneous Restrictionism! wrote: But it could be something else..that just happened to be "similar" to your problem!
It could be the Ignition Module! It could be a timing issue!(CAM sensor) It could be fuel issues!(Fuel injection system) It could be MAF issues! It could be TPS issues! It could be ANYTHING!
No I dont see your point, or lack there of.
The reason I ASKED him if it has been done is quite legitimate. You are correct, it COULD be anything, but, through asking the right questions, and getting the proper answers, we can narrow it down. I did not tell him to go out and buy new wires and that will fix the problem. I told him if it is due for a tune up, complete the tune up and check back. Would you have preferred I kept my anecdote to myself?
The fact that the motor is 14 years old changes nothing. It still runs on the same principals it was created with 14 years ago. 14 year old motors still need regular maintenance, and tune up parts.
All you have to say is "bring it to a reputable technician". Oh yeah, you threw out a great suggestion... What the hell does elevation factor have to do with ANYTHING?
Anyways, I think we need to hear back from d114125 before we can proceed too much farther.
 Posted: Thu Jan 11, 2007 11:32 am |
88delta88 wrote: All you have to say is "bring it to a reputable technician". Oh yeah, you threw out a great suggestion... What the hell does elevation factor have to do with ANYTHING?
Like I said "I'm probably wrong" with the elevation bit!
Bringing a vehicle to a tech is probably the best logical idea! Thats why that trade exists. It has nothing to do with incompetance by going to a tech, just so you know! It saves time and frustration in the end.
Is it an ego thing to not have another guy/or girl fix you car?
Nothing wrong with trying to execute the mechanical problem in the fastest and simplest way!
Wrong of me suggesting that?...hmmm! What would you suggest be done...Logically of course?
I know!... It's so hard to understand someones point of view, when all you see is what you don't know!
But hey! Change the plugs and wires, if it works, it works. If it doesn't then what?
I would rather use my own suggestion, I have enough confidence in myself to make the right choice.
It just goes to show that the first place you would go to if you had car issues, is here!
If you bought a Ford would you join a "Ford" site?
Age of a motor has alot to do with anything that happens to one.
If you had a choice between a '95 motor or a '90 motor which would you trust?
85cieraholiday
 Posted: Thu Jan 11, 2007 12:54 pm |
Erroneous Restrictionism! wrote: 88delta88 wrote: All you have to say is "bring it to a reputable technician". Oh yeah, you threw out a great suggestion... What the hell does elevation factor have to do with ANYTHING?
Like I said "I'm probably wrong" with the elevation bit! Bringing a vehicle to a tech is probably the best logical idea! Thats why that trade exists. It has nothing to do with incompetance by going to a tech, just so you know! It saves time and frustration in the end. Is it an ego thing to not have another guy/or girl fix you car? Nothing wrong with trying to execute the mechanical problem in the fastest and simplest way! Wrong of me suggesting that?...hmmm! What would you suggest be done...Logically of course? I know!... It's so hard to understand someones point of view, when all you see is what you don't know! But hey! Change the plugs and wires, if it works, it works. If it doesn't then what? I would rather use my own suggestion, I have enough confidence in myself to make the right choice. It just goes to show that the first place you would go to if you had car issues, is here! If you bought a Ford would you join a "Ford" site? Age of a motor has alot to do with anything that happens to one. If you had a choice between a '95 motor or a '90 motor which would you trust?
If the poster wanted to bring the car right to a garage shouldn't the first post have read something like "Questions to ask my mechanic" or "Whats a fair price to expect for repairs a,b,c and d"?
If the car hasn't had a tune up is a while, why wouldn't that be a good place to start?
"Is it an ego thing to not have another guy/or girl fix you car?"
Not everyone has the money to pay for the high hourly rate that repair centers demand. Why would you want to spend money on something you can do yourself?
"I know!... It's so hard to understand someones point of view, when all you see is what you don't know!"
I guess so because its been a problem for you since the day you got here.
"I would rather use my own suggestion, I have enough confidence in myself to make the right choice."
I'm glad you do because I sure as hell don't have any confidence in you.
"If you bought a Ford would you join a "Ford" site?"
What does this have to do with the 1st post?
"Age of a motor has alot to do with anything that happens to one.
If you had a choice between a '95 motor or a '90 motor which would you trust."
The "age" can mean more then just the year the engine was built, have you though of the maintenance ,mileage or if the engine has any known problems?
Heres something to think about, if my 1985 Oldsmobile has 80,000 miles and my uncles 1988 Oldsmobile has 332,000 miles which do you think I have more trust in? Which is old in more ways then one?
_________________ .
87Delta
 Posted: Thu Jan 11, 2007 1:04 pm |
Erroneous Restrictionism! wrote: Age of a motor has alot to do with anything that happens to one. If you had a choice between a '95 motor or a '90 motor which would you trust? Engine age has nothing to do with it. A 2007 engine could do the exact same thing. Erroneous Restrictionism! wrote: Now this guy is gonna go off and get new wires and plugs, if the problem isn't fixed he just wasted money and has to start all over. Did 88delta88 anywhere say he should go out and buy new wires? He merely stated the owner should check condition of the wires, not just go out and replace them. Don't jump to conclusions. He only said if it looks in need of a tune-up then do it and come back with the results. Erroneous Restrictionism! wrote: ...Bring it to a reputable technician.
How does this help? The original poster asked for help because he/she wants to solve it on their own, not take it to a shop.
d114125
 Posted: Thu Jan 11, 2007 1:33 pm |
Hi everyone, thanks for your input, before undertaking journey, replaced all spark plugs, 1 coil pack, oil and filters, as stated only happened after approx 2hrs hard driving in overdrive, 80mph plus when changed down into drive did not happen until after covering 450miles constant driving, engine sounds good on tickover and when revving, no miss or back fire, obviously cannot get under bonnet while doing 80mph, dont trust her indoors ha ha, dont think these were sold in europe, this is imported , not my first yank, just sold 1997 dodge ram dually cummins awsome piece of kit. wish i had kept it. my impression of fault is something getting hot and breaking down under load electrical, have pretty good knowledge of cars as in trade here, as for taking to technician, if they deal with american cars here they just want to rip you off. so any advise is a great help.
 Posted: Thu Jan 11, 2007 1:41 pm |
87Delta wrote: Erroneous Restrictionism! wrote: Age of a motor has alot to do with anything that happens to one. If you had a choice between a '95 motor or a '90 motor which would you trust? Engine age has nothing to do with it. A 2007 engine could do the exact same thing. Erroneous Restrictionism! wrote: Now this guy is gonna go off and get new wires and plugs, if the problem isn't fixed he just wasted money and has to start all over. Did 88delta88 anywhere say he should go out and buy new wires? He merely stated the owner should check condition of the wires, not just go out and replace them. Don't jump to conclusions. He only said if it looks in need of a tune-up then do it and come back with the results. Erroneous Restrictionism! wrote: ...Bring it to a reputable technician. How does this help? The original poster asked for help because he/she wants to solve it on their own, not take it to a shop.
So your repeating what everyone else has said!
Get an original thought!
 Posted: Thu Jan 11, 2007 1:42 pm |
d114125 wrote: Hi everyone, thanks for your input, before undertaking journey, replaced all spark plugs, 1 coil pack, oil and filters, as stated only happened after approx 2hrs hard driving in overdrive, 80mph plus when changed down into drive did not happen until after covering 450miles constant driving, engine sounds good on tickover and when revving, no miss or back fire, obviously cannot get under bonnet while doing 80mph, dont trust her indoors ha ha, dont think these were sold in europe, this is imported , not my first yank, just sold 1997 dodge ram dually cummins awsome piece of kit. wish i had kept it. my impression of fault is something getting hot and breaking down under load electrical, have pretty good knowledge of cars as in trade here, as for taking to technician, if they deal with american cars here they just want to rip you off. so any advise is a great help.
Thank you for answering my questions
 Posted: Thu Jan 11, 2007 3:04 pm |
85cieraholiday wrote: "Is it an ego thing to not have another guy/or girl fix you car? "
"if they deal with american cars here they just want to rip you off. so any advise is a great help. "
"Thank you for answering my questions "
What the hell are you talking about, everyone else is trying to help him and you just want him to go to a shop which even the owner of the car in question says he doesnt want to do.
Erroneous Restrictionism!, Its amazing how you twist things to sound as if your the hero and all knowing. If anything the poster answered 88Delta88's post not yours.
Sure!....
 Posted: Thu Jan 11, 2007 3:44 pm |
Erroneous Restrictionism! wrote: Like I said "I'm probably wrong" with the elevation bit! Why would you throw something out there that you thought was wrong to begin with? Erroneous Restrictionism! wrote: Bringing a vehicle to a tech is probably the best logical idea! Thats why that trade exists. It has nothing to do with incompetance by going to a tech, just so you know! It saves time and frustration in the end.
Is it an ego thing to not have another guy/or girl fix you car? Most of the time, its a monetary issue. Erroneous Restrictionism! wrote: But hey! Change the plugs and wires, if it works, it works. If it doesn't then what? After the required work is carried out, do like I said, and check back. If the problem remains, we keep troubleshooting. Look up that word, troubleshooting, while you're at it. Erroneous Restrictionism! wrote: I would rather use my own suggestion, I have enough confidence in myself to make the right choice. Good to hear you make your own choices. Let d114125 make his own. Erroneous Restrictionism! wrote: Age of a motor has alot to do with anything that happens to one. If you had a choice between a '95 motor or a '90 motor which would you trust?
That really depends on how well it was MAINTAINED.
