It is currently Thu Nov 26, 2026 10:09 am
 Post subject: 94 Olds Cutlass Ciera
PostPosted: Sun Jan 14, 2007 1:55 pm
got a problem with the car shuddering and dying. just had the battery replaced, new spark plugs put in yesterday. before this the car started up roughly, sputtered a bit then slowly died. this has been a problem for the past 3 days or so. i thought maybe it was the fuel filter, but thats been replaced in the past 2 years as well. the cars in great shape, but for some reason when its started up it idles roughly and if you dont give it gas or get it movin it kinda slowly dies. it died on me today in the middle of an intersection. so id really appreciate some feedback.
PostPosted: Sun Jan 14, 2007 3:32 pm
Images: 1
Are you getting any trouble codes?..
A few things come to mind:
Fuel Pressure Regulator.....
Ignition Module....Check your grounds!
Mass Air Flow sensor.....May have quit on you!
Exhaust Gas Recirculator....May be seized!
The wiring to/from the Fuel Pump might have a short/bad ground! (If it were the Pump itself the car would not start at all)
Do you have a digital
Ohm metre?
PostPosted: Sun Jan 14, 2007 5:18 pm
I would try the fuel filter again, just to eliminate it. What I am seeing, at least in the outdoor power equipment/power sports industry is that fuel is not as good as it was a couple years ago. If you had an excess amount of water, the filter might catch that and become restricted. Just a thought, and its fairly easy to replace.
Otherwise it could be any one of the things ER suggested, or something else 8-)
My Lumina, which shares platforms with your car did something similar when a couple fuel injectors were out of it.
If you have the 3.1, there are several plastic vac lines that go underneath the upper plenum and they are known to crack. My car also showed similar characteristics when this occured.
Not saying that any of the above are true with you, but its something to look for.
Regards,
PostPosted: Sun Jan 14, 2007 5:24 pm
What engine is in the car? Aprox how many miles on that engine. Are there any other parts recently replaced on the car that may be apart of your problem?
I had a similar sounding problem with my 2.5L when the ignition module went. That may be something you should keep in mind.
PostPosted: Mon Jan 15, 2007 1:38 am
Hi JackAssoms, hello everyone,
........ for some reason when its started up it idles roughly and if you dont give it gas or get it movin it kinda slowly dies ........
I read, that it runs OK above idle. Does that include wide open throttle (WOT)
If so, the fuel system (and the fuel) is not the problem.
Nor is the exhaust gas recirculation (EGR) system or Mass Air Flow (MAF) sensor.
Vacuum leak is a good guess, until you give us more information.
