It is currently Thu Nov 26, 2026 11:04 am
 Posted: Fri Jan 19, 2007 7:18 pm |
It could be anywhere. Start at the master cylinder, follow the lines until you find the wet spot.
Regarding the engine in your car... Whats a V4? Should be an inline 4...
 Posted: Tue Jan 23, 2007 7:37 pm |
88CuttyCutty wrote: alright, so earlier today i went to set out on finding my leak, and i opened the cap on the brake cylinder and noticed that all of the fluid was still in there even though the brake light was on. the fluid changed to a dark brownish yellow. the master break cylinder is brand new, but somehow its not feeding it, like theres a clog or something. im not really sure where to go from here so any help would be appreciated.
do you have brakes? brake light will come on for one of 2 reasons. Either the parking brake switch has been activated, or you have low fluid.
 Posted: Tue Jan 23, 2007 11:54 pm |
Quote: ........ the fluid changed to a dark brownish yellow. the master brake cylinder is brand new ........ Assuming a new M/C, the fluid wasn't changed, so the job was not properly done. Have the fluid changed and the brakes bled properly. andrewk wrote: ........ brake light will come on for one of 2 reasons ........ Make that three. If the bypass valve in the M/C is in the wrong position, it will show a low fluid light, regardless of the actual level. Brando wrote: ........ The switch could be faulty ........
Or the brake could be engaged.
 Posted: Wed Jan 24, 2007 4:58 pm |
88CuttyCutty wrote: ........ i dont understand now is that the brake is off and there is fluid in the M/C, and teh light is still on. Your question was already answered. Here it is again: 88 Coupe wrote: ........ If the bypass valve in the M/C is in the wrong position, it will show a low fluid light, regardless of the actual level ........ 88 Coupe wrote: ........ the job was not properly done.
Have the fluid changed and the brakes bled properly ........ Your first question was also answered. Here it is again: andrewk wrote: ........ Start at the master cylinder, follow the lines until you find the wet spot ........
I'm finished with this one.
 Posted: Wed Jan 24, 2007 6:59 pm |
Eventually? I don't get it. New brake lines can be found at a parts store. If you found a leak in a line, replacing said line will fix the problem, but you still have to bleed the ENTIRE system out to ensure all the air gets out.
I'd suggest taking it to a shop, and seeing if you can watch them do it- might be the best way for you to learn.
