It is currently Tue Nov 17, 2026 3:16 am
Cutlass95Ciera
 Posted: Thu Jan 08, 2004 8:47 am |
73Delta88 wrote: I was actually pretty nice to them. (only a couple little smoke shows)... hehe
SURE
Psyco Diver 69
 Posted: Thu Jan 08, 2004 12:41 pm |
Yea thats what I used to tell my parent when I needed tire every 3 month on my old 85 Cutlass.
_________________ Jake 19/m
1972 Olds Cutlass- Parts car
 Posted: Thu Jan 08, 2004 5:26 pm |
my tires get maximum life... I cant light my tires up...
strokercutlass
 Posted: Thu Jan 08, 2004 10:12 pm |
| TOC Mechanic |
73..the Dunlop GT Qualifier is more of a performance line tire, which tends to be made of a softer compound. Dunlop is also a subsidiary of Goodyear, in case you weren't aware. The 60-70-and 80,000 mile tires tend to have a heavier constructed belt package and sidewall, designed to go for a longer mileage without incident. Unfortunetly, many of them tend to be harsh riding, with worse wet traction because of the design compound of the rubber, which is made harder to last for a longer mileage. I dont deal much in the Dunlop line anymore, since they're a Goodyear affiliate, and with Goodyears finaincial difficulties as of late, I'm seeing alot of their financial problems roll downhill into their tire construction and quality, with ride vibration and construction issues, so I've tried to address the problem by going to brands that I have good luck with instead, but if i remember correctly, they're in the 45-50,000 mile range. Also, remember your car is NOT what you'd call "light"...  so that will also have an effect on tire wear and longevity.
No53Alero
 Posted: Fri Jan 09, 2004 5:38 pm |
Joined: Mon Jun 09, 2003 10:30 pm Posts: 156 Images: 42 Location: CINCINNATI, OH
i'm running 195/60/14 kelly charger HR's on my car. They hold the road awesome they are 60k mile tires. They ride awesome w/ no sound too. i've put 15k w/ no visible wear yet.
_________________ One and Only Airbagged ciera!!
Final 500 Alero website
