It is currently Sun Nov 08, 2026 4:04 pm
 Post subject: Idler Pulley
PostPosted: Thu Feb 08, 2007 12:57 am
Ok where should i start! I was driving my car earlier today and everything was alright. I went to use it again and the voltage light appeared, I got nervous and tried to drive to the nearest auto zone for a battery and alternator inspection. Well I did not make it because when my power steering started to not work, I left the hood up and noticed the belt that goes around the alternator was off. My question is does this sound like a idler pulley issue?
94 88 Delta Royal 116,000,
 Post subject: Re: Idler Pulley
PostPosted: Thu Feb 08, 2007 2:47 pm
Did you inspect your belt for any problems? When the belt is properly in place, can you remove the belt using only your hands, or do you require a tool to loosen the idler?
PostPosted: Fri Feb 09, 2007 1:42 am
It was the idler pulley my husband replaced it today! So hopefully everything will work out ok.
