Alright...assuming you know the general process of changing oil, which gravereaper0 has so kindly reminded us about...
First of all, here are some specifications:
Fluid Capacity:
With the change of filter,
6.5 quarts of oil is required. 5W-30 is the recommended engine oil viscosity.
Torque Specifications:
Oil Filter Canister - 18 lb ft (25 N*m)
Drain Plug - 15 lb ft (20 N*m)
You'll need a special type of socket to remove the canister, I happened to have one laying around here when I got my intrigue (Coincidence?), so it's not really a proprietary type of socket (not necessary to buy from GM).
The Kentmoore tool that GM recommends is the J 29142.
Usually expensive! and not easy to find.
The tool I am using is made by a company called CTA Tools, RiteFit, model A250. Not sure of other brands, but this should help you pick out an oil filter socket at the local auto parts store.
If they don't carry the CTA Tools RiteFit brand, the specifications of the socket are:
Diameter: 74/76mm No. Flutes: 15
Here's a link if you can't find one local:
RiteFit A250
Resetting the change oil light, the gas pedal procedure is what works for me. Turn ignition to on position, don't crank it. Press gas pedal fully 3 times within 5 seconds of turning the ignition to the on position. You'll see the change oil light start to flash and that means it is resetting, you can turn the ignition off, and start the engine up. It should turn the light off. Do this procedure after every oil change, even if the light isn't on. Otherwise the "oil life monitor" will still be stuck on your last oil change and you'll have the inconvenience of the oil light turning on when it shouldn't.
Here's what GM lists for resetting the light:
1. Turn the ignition to ON, with the engine off.
2. Fully press and release the accelerator pedal three times within five seconds.
3. If the CHANGE OIL light flashes, the system is resetting.
4. Turn the key to OFF after the light has finished flashing, then start the vehicle. If the CHANGE OIL light comes back on, the engine oil life system did not reset. Repeat the procedure.
I think that covers most of it...any more questions feel free to ask.
