Just got a different engine in and it runs. Tried reading codes, but has OBDII style connector. Listed OBDI on label under hood. Tried OBDII code reader, it connects, but will not power up. Is there a way to read codes like on older OBDI with paper clip? Thanks!
You need an OBDII/I code reader, one that does both.
If you have a 16 pin OBD II connector, then it is not possible to flash codes. Apparently some came with a 12-pin which you could ground A to B like a regular OBD I system to flash the codes.
Users browsing this forum: Google Adsense [Bot] and 11 guests
