wow, no replies...sorry bout that.
The blower motor would be located on the passenger side, in the engine compartment, and mounted to the firewall.
You might want to check the relay, as well as the blower resistor. Easiest thing to do would be disconnect the blower harness, and "bench test" the blower motor to make sure the motor itself didn't burn out.
Here is a diagram for reference:
Hopefully that helps, any further questions, let us know.
