It is currently Mon Nov 09, 2026 4:32 pm
 Page 1 of 1 [ 9 posts ]
PostPosted: Sat Mar 10, 2007 6:29 pm
Images: 9
Saludos. Just a few days ago I tested the compression of my Vista Cruiser '75. The engine is 445 (396021Fa), and the compression, I think, it's too low. 60-75 psi for each piston. I know since 1973, Olds started to produce low-compression engines, but, I don't have the owner's manual, so I don't know what were the original compression of this engine. Any one knows?
Regards from Mexico.
PostPosted: Sat Mar 10, 2007 7:14 pm
tolesco wrote:
........ I think, it's too low. 60-75 psi for each piston ........
As you asked it, the FSM will not have the answer to your question. They will only show an allowable difference between the lowest and highest cylinder, and that is only a starting point.
At the time you did the test:
Was the engine at normal operating temperature?
Were all the spark plugs removed?
Was the carb open fully?
Were there four compression strokes during the test of each cylinder?
How many are 60# and how many are 75#.
Show us the readings by cylinder.
1 = ?
2 = ?
3 = ?
4 = ?
etc.
PostPosted: Sat Mar 10, 2007 10:39 pm
Images: 9
Saludos. Well, here is some more information:
Was the engine at normal operating temperature? - Yes
Were all the spark plugs removed? - Yes
Was the carb open fully? - No, my bad...
Were there four compression strokes during the test of each cylinder? - Yes
Here are the readings from each cylinder:
1=60 psi
2=55 psi
3=65 psi
4=60 psi
5=65 psi
6=60 psi
7=70 psi
8=75 psi
psi=Pounds per Square Inch
It was a mistake didn't open fully the carb, in some days I will make another test, this time, with the totally opened carburetor.
PostPosted: Sun Mar 11, 2007 7:25 pm
tolesco wrote:
........ I will make another test, this time, with the totally opened carburetor.
Your numbers will be higher. There is no reason for concern, either way.
If it doesn't leak or smoke and all cylinders fire when they are supposed to, relax and enjoy driving it.
PostPosted: Sun Mar 11, 2007 10:17 pm
Images: 9
Ok, jaja, now I have another problem, this time, with a light on the instrument's panel. When I turn on the car , the light do it too. The light says GEN... what can be?
- An excuse, my english is not very well.
PostPosted: Sun Mar 11, 2007 11:18 pm
I assume that would be the Generator light.
PostPosted: Mon Mar 12, 2007 12:46 pm
tolesco wrote:
........ When I turn on the car , the light do it too ........
The "gen" bulb should light when you turn the ignition switch to "on". This verifies than it is operational. It should go out as soon as the engine starts, showing that the charging system is working properly. It will stay on, anytime the current reaching the battery, is less than it should be.
If the belt is not slipping, your alternator and/or its regulator might be bad. It is possible, a wire or ground connection may have worked loose.
PostPosted: Sat Mar 24, 2007 3:11 pm
Hello, In 1975 the 455's with Auto trans, Auto tran/AC, Auto Calif all had 8.50:1 Compression. Hope that helps
Have a Good One
I'm just an Oldsmobile Guy.
PostPosted: Sat Mar 24, 2007 9:02 pm
He is in Mexico, and did not say whether it is a CA, or a 49 state car.
The compression reading in question, is the cylinder pressures at cranking speed. Nothing to do with the "advertised" numbers you posted.
Users browsing this forum: Google [Bot] and 34 guests
