 Page 1 of 1 [ 10 posts ]
 Post subject: 85 Ciera air cleaner
PostPosted: Sun Mar 11, 2007 10:29 pm
This is I'm sure a dumb question but.....I am trying to do periodic maintenance on my wife's 85 Ciera LS, 3.8L V6, and cannot get at the air filter inside the canister air cleaner. I have removed the 90° elbow hose on top, and there is a wing-nut below that which I removed, and I can see the pleated paper filter, but I can find no way to actually open the metal canister to change the filter! It appears as if it should separate into the lower half which is bolted to a bracket on bottom, and the upper half, but it does not. Yes, I have also removed the two 10mm bolts that connect the upper portion to the thermostatic valve further along the hose.
How do I get this air filter replaced?
I just read on this forum that the gas filter is behind the rear wheel.....after I gave up searching for it this afternoon all over the engine compartment. :roll:
...glen
 Post subject: Re: 85 Ciera air cleaner
PostPosted: Mon Mar 12, 2007 10:48 am
Ive had this same problem on my Ciera with the 2.5, I got the cover off by using a thin flat head screw driver to carefully pry off the cover. Remember should be a little rubber gasket around the edge of the cover, so watch you dont rip it (though it shouldnt be an issue unless you really dig the screw driver in there). You shouldn't have had to take everything else off (except the wing nut) as the filter comes out through the top.
PostPosted: Mon Mar 12, 2007 12:53 pm
Thanks, but you have an L4, which has a different air cleaner assembly.
The stock filter for an '85 L4 is AC Delco A785C, while the 3.8L V6 uses a A633C in a different, canister-type cleaner assembly.
I need to know if the 3.8L V6 air cleaner housing comes apart in the middle, or some other way.
...glen
PostPosted: Mon Mar 12, 2007 1:16 pm
Hey glen, uve pretty much got it, i bet its been a while since ur air filter assembly has came off. The top half is probably sticking from age, just tap the upper half of the air cleaner assembly all around with a plastic hammer to loosen the top from the bottem.
Youve got the 90 and 2 10 mm bolts and the wing nut so the top half should pull straight up and out.
PostPosted: Mon Mar 12, 2007 8:03 pm
Well, although the car is really low milage for its age, we've had it for a couple of years so I'd bet it's not been apart for at least three.
Tap all around with a plastic hammer....hmm, not a lot of swing room there with the radiator and battery, but I'll give it a go. I already tried tapping with the handle of a large screwdriver and prying with a screwdriver blade, to no avail. :roll:
I'll try to get on it this week at work. I work in a small tire and front-end/brake shop, so you know we never have time to work on our own vehicles! :wink:
Thanks for the info....good forum here.
...glen
PostPosted: Mon Mar 12, 2007 10:08 pm
...glen
I know we have different engines, but the air filter ass. is similar in design. What I put above will work on many other cars, as its just the lid getting stuck on the rest of the ass. which Ive seen a other older cars including my own.
PostPosted: Mon Mar 12, 2007 10:28 pm
OK, thanks, 85cieraholiday, I'll let you all know how bad I mangle it. :twisted:
...glen
PostPosted: Tue Mar 20, 2007 1:54 am
Hey glen
How did the air filter assembly removal work out for you?
PostPosted: Sat Jul 11, 2009 4:39 pm
Geez! Sorry for never getting back to you on this, for over 2 years! Many things were happening and I could not get to the forum for a while (moved, illness, parents died, and so forth).
Just to let you know, I never could get the air cleaner canister apart, and eventually took the car to a shop for work (codes, sensors), and had them tune it and replace the filter. They said they had to get the unit unbolted from underneath and take it out of the car, in order to get the halves apart on the bench. Nice design! :)
The car has not run well for a while, and it is in my garage while I figure out how to fix it well enough to sell. I just bought a certified used Sentra for the little woman to drive instead.
PostPosted: Sun Jul 12, 2009 2:42 am
Images: 1
better late then never
