It is currently Thu Nov 19, 2026 5:18 am
 Page 1 of 2 [ 28 posts ]  Go to page 1, 2  Next
 Post subject: Too Hard to Start
PostPosted: Fri Jan 09, 2004 5:25 pm
After my car has been siting for 3 hrs or more, it takes a good amount of time to turn over, and when it is trying to turn over, the engine seems to strain really hard. The starter is only 10 months old, any ideas? :roll:
PostPosted: Fri Jan 09, 2004 5:27 pm
Battery....I just recently had to recharge mine since it wouldn't even start...just a "click..click...click...click"
A battery with high cold cranking amps is what you want....
PostPosted: Fri Jan 09, 2004 7:00 pm
check for bad connections or corrosion on the battery terminals.... you'd be suprized how much a little corrosion can lower the power available to your starter.
if that's fine I'd say to load test the battery. If you dont have a load tester you could probably get someone at a shop to do it for next to nothing.
PostPosted: Fri Jan 09, 2004 10:49 pm
Images: 8
I agree but make your fuel system is running clean and what weight oil are you using.
Jake 19/m
1972 Olds Cutlass- Parts car
PostPosted: Fri Jan 09, 2004 11:16 pm
The battery is only a few years old (like 2 or 3) and the connections do not have any corrosion. The car as I said has a new starter (from may 2003) and it has 10-30 oil in it (which is what the book says 2 use). The car only has 72,800 miles on it.
PostPosted: Fri Jan 09, 2004 11:55 pm
Images: 8
Its seems your battery might be to old then. You can bring them to most parts stores and have them test it for free to tell you if your battery is bad or not
Jake 19/m
PostPosted: Sat Jan 10, 2004 2:20 am
Images: 12
My battery is 3 years old and it's starting to go. I have the same problem in the cold. I took it to pep boys cus I heard they will check them for free, which they did, and it tested low.
PostPosted: Sat Jan 10, 2004 6:38 pm
next question...
what make/brand of battery?
If its a Wal Mart "NEVERstart", then you've found your problem...otherwise, I'd still tend to lean towards the battery, unless theres something thats draining the battery in that amount of time. I'd take it by somewhere and have them do a load test on it just to be sure. For a new battery I'd suggest either an Interstate or an Optima. They're a little more expensive, but how much is it worth to you if your car is dead in the cold???
PostPosted: Sat Jan 10, 2004 8:12 pm
i agree with stroker, if it is the battery, i highly reccomend Interstate. my MT-78 is 4 years old, has been run dead 3 times (twice from having the stereo cranked while tailgating, and once when my alternator went), and takes a beating everyday from my stereo and it still starts the car everyday, even this morning when it was 9 degrees. if you can fit a bigger battery in there, the number is MT-78, if not, you will need an MT-75.
PostPosted: Sun Jan 11, 2004 12:27 am
Images: 12
strokercutlass wrote:
next question...
:thumbup: Exactly what I found out the hard way! I bought one for my old car at Meijer last year, and it lasted about a week.
p.s. If you don’t live in the Michigan, Ohio, Indiana, Illinois area...Meijer is our version of Wal Mart
PostPosted: Sun Jan 11, 2004 12:36 am
next question...
Cept Wal-Mart usually doesn't sell groceries....unless it's one of those super wal-marts or whatever the hell you call em....
PostPosted: Sun Jan 11, 2004 12:45 am
Images: 12
Well they are selling groceries around here, all of the new wal-marts moving in start out as normal ones, and then go to super centers. Then it really takes away from Meijer, and that's why I might not have a job this time next year :lol:
PostPosted: Sun Jan 11, 2004 12:54 am
AHA!
You work at Meijer....I was thinking about working there....I got an application and everything...but then I got in the personality of I'm too good to work at Meijer....LMAO
I'm looking just to do jobs online....like web sites and stuff....
How much does Meijer actually pay you? And what do you do there?
PostPosted: Sun Jan 11, 2004 12:57 am
Images: 12
well they pay me 8 bux an hour....but i've been there for almost three years. I work in the produce departement, third shift. I started out as a bagger, if I recall correctly it pays just under six bux an hour. You get a raise every 700 hours you work. It may sound like alot, but if you work 40 hours a week during the summer, the hours sure can add up fast :lol:
It sux being a bagger, but you can get promoted, it took me almost two years! I'm with you on the web jobs. I would LOVE to work from my computer :thumbup:
PostPosted: Sun Jan 11, 2004 3:38 pm
I just went outside and checked what kind of battery it is. Its a NAPA power 60.
