It is currently Mon Nov 16, 2026 1:24 am
 Page 1 of 1 [ 10 posts ]
PostPosted: Wed Mar 14, 2007 12:32 am
I have a 1997 cutlass supreme v6 3.1L. My speedometer starts jumping up and down. Then it goes to 0 and my trans won’t sift into gears. The odometer stops working when this happens. Can someone please HELP! What could be the problem?
PostPosted: Wed Mar 14, 2007 4:43 pm
Are you getting any codes set?
My impression is the Vehicle Speed Sensor (the wiring or the sensor itself), but that should set a code.
VSS is a Permanent Magnet (PM) generator mounted in transaxle/transmission. The VSS sends a pulsing AC
voltage signal to PCM, which PCM converts into miles per hour (MPH). VSS signal is used by PCM in
controlling TCC and shift solenoids. Signal may also be used for instrument cluster speedometer and cruise
control system. Failure in VSS circuit should set a related diagnostic trouble code.
PostPosted: Thu Mar 15, 2007 11:10 am
Just found out there are 3 different speed sensors on this car. Which one should I change? Inter, outer, or steering?????
PostPosted: Thu Mar 15, 2007 4:35 pm
You didnt mention if you have a check engine light on or not. It would be important. It might lead you straight to the offending sensor.
You said the transmission doesnt shift properly?
PostPosted: Thu Mar 15, 2007 11:50 pm
Hi Rich951, everyone,
Brando wrote:
VSS is a Permanent Magnet (PM) generator mounted in transaxle/transmission ........
Not a job for a beginner, but since it's accessible without removing the trans, the labor shouldn't be too bad.
Any competent trans shop can diagnose it, and give you a price at the same time.
PostPosted: Sat Mar 17, 2007 4:18 pm
The sensor I am talking about was described above, it is called the Vehicle Speed Sensor (VSS) and it is mounted in the transmission. It controls a lot of things, including shifting, as well as the speedometer reading.
Definitely get your computer scanned for codes.
PostPosted: Mon Mar 19, 2007 7:17 am
THANKS EVERYONE!!!!!!! IT WORKS!!! I Changed the vss on trans and everything is working good...
PostPosted: Mon Mar 19, 2007 9:17 am
Well, glad to have been able to help and thanks for the update.
PostPosted: Thu Jul 26, 2007 8:19 pm
Im having the same problems, about 4 months ago i put in a new speed sensor and it run like new. 2 days ago my the speedometer quit working and my low oil level light comes on every time I start the vehicle and the trans is acting up again. WHATS WRONG WITH MY CAR!!!!! HELP
PostPosted: Fri Jul 27, 2007 9:03 am
Low oil light, no speedometer, trans acting up... You've got a bad ground it sounds like to me. Wiring problems are a pain. Is your check engine light on this time?
