It is currently Fri Nov 13, 2026 10:44 pm
 Posted: Sun May 13, 2007 1:49 pm |
is it making spark? Does the rotor rotate when the engine turns over? Have you verified presence of fuel at the carb?
 Posted: Mon May 14, 2007 1:55 am |
88delta88 wrote: ........ Does the rotor rotate when the engine turns over? ........
And do the points open and close?
If so, pull the coil wire from the dist cap, hold it about ¼" from the closest ground, and have someone crank the engine. If you get a spark, replace the cap and rotor.
If not, adjust the points to .016" gap, or 30° dwell. If it still doesn't start, replace the points and condenser.
 Posted: Mon May 14, 2007 6:04 pm |
88 Coupe wrote: And do the points open and close? ........
Best to start at the beginning.
Using a test light or VOM, verify there is power at the + side of the coil. If so, check for a pulsating signal, at the - side, while the engine is being cranked. If not, continue with the above instructions.
 Posted: Mon May 14, 2007 6:06 pm |
Hi incog,
Quote: ........ After having my dad take a look ........
How old is your Dad?
 Posted: Wed May 16, 2007 8:23 pm |
incog wrote: ........ my father is 51. Thanks, that explains a lot. incog wrote: ........ it's also a good idea to lubricate the distributor cam ........ ........ to save the rubbing block ........ Not just a good idea. When the block wears, the point gap closes. When the gap closes enough, the engine stops running. With no lube, it can happen in less than 20 miles. Part of the normal (about 10,000 mi.) maintenance, is to open the gap in order to compensate for normal wear. Quote: ........ with a small amount of cam lube or white lithium grease ......... The proper lube should still come with the points. Dielectric grease is a good substitute. Quote: ........ It may help from experiencing other ignition problems.
Only the one I described above.
